2 members (BC59, Danielbolt),
210
Mod | | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | i found out today i have a 1956 235 engine, is there an up today tranny that will connect to it.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | A t5 will work with a little modifications. There are several muncie, saginaw, and warner transmissions that will bolt right up. use the search feature, or ask more specific questions. the best transmission for your truck will depend on budget, and how you plan to drive/use your truck.
If your truck has a torque tube, you will likely have to swap out the rear end for an open drive rear.
If you have a 1 ton, or a heavier chassis, you may want a heavier transmission like an A833, which was used in gm trucks with the designation my6. Over drive will give your truck new life assuming the breaks are also in proper working order.
Here is a partial list of transmissions that will bolt up.
Warner T10 4 speed muncie m21/m22 4 speed muncie sm318 3speed muncie sm420 4 speed muncie sm465 with a little modification 4 speed Warner t5 5 speed Kieseler/tremec tko 5 speed heavier duty than t5 A833/MY6 4 speed Overdrive Clark heavy duty 5 speed etc | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | tremec T5 http://www.ttcautomotive.com/English/products/T-5.aspor T5 hybrid camaro guts in an S-10/15 housing.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | sound like you know what you are talking about, do you know what vechicle that would have one that i could get not to exspensive that will bolt right up to. , the truck i got has the slow grannnnnny gear, the gear shift has some much slop that can figure out where 3rd and 4th is.the truck is a 3/4 ton, if i could change the rear end and transmission, it would be sweet. real sweet. its a flat bed and you dont see many of them. i plan to use it as a driver, to car shows and stuff, just like to cruise down the road, not worrying if it will make it, the brakes are great, its a little slow, motor has been rebuilt and runs like a charm, have a low budget, on disablitly and my frineds help me.bought the truck for 800.00 and got it running in a few days,
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I know what you mean about the slop... I had the same problem with my 59 with the sm420 granny low transmission. I would reccomend a heavier transmission for a 3/4 ton truck. The A833(my6) would be high on the list, but it will take some machining to make it a bolt on deal. Your 3/4 ton likely has 4.57 gears. You can swap the pumpkin out for a 4.11 gearset. An overdrive transmission with a .73 final drive will give you an effective 3.34 gear ratio with your stock gears. That would put you around 2350 rpm @65 mph with 31 inch tall tires. You would be at 2113 rpm if you changed the rear gears to 4.11 with the same OD transmission and tires.
| | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | i wont be hauling nothing, it will be a garage sleeper. the pumkin is that the rear end? that thing is as big as a wash tub. will it help me to change it out or both.something cheap now.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | well, on the cheap end why not just try the T5 swap. The T5 was a 5 speed found in a variety of vehicles. You probably would want 1 out of a chevy s10 pickup. You should be able to leave your rear end alone for now. The t5 is not a heavy duty transmission, and may not live long in a heavier vehicle, but it should match up pretty well with a 235's powerband.
With any transmission swap you will likely have to have a new driveshaft made.
| | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | you think it will hook right up with no problem. you mentioned modifiations | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | go to this site http://www.stovebolt.com/techtips/t5tranny.htm it will tell you most of what you need to know. becareful of the year of the trans some have a electric sending unit for the speedo, costly. ron btw i have a t-5 in my 54/3100 and i love it. but as i get older i sometime wish an auto. more expense in the long run but if you live in a high traffic area might be worth while. i didn't want to spend the extra 1500.00 at the time now i wish i had for many reasons. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | will a s10 out of a 4 cylinder fit? | | |
