1 members (JW51), 186 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#45011 10/21/2003 7:12 AM
ape
Offline
HI GUYS. 1ST TIMER HERE. A MECHANIC PAL IS PUTTING A COMPLETELY REBUILT 1962 STOVEBOLT 261 IN MY 1940 CHEV HALF TON. It'll have a 3:55 rearend. My question is ,will the gearing in the original 4 speed tranny be too low for this set up ?? I kept the original 216. Truck is original other than these changes and 12 volt. Thanks,jim
#45012 10/21/2003 7:21 AM
The factory gearing was 3.90 or 4.10 most likely. Your four speed has direct drive forth, no over or under drive. It should be a great combination. I run a 250 with automatic and 3.42 rear axle in a '37. At 70 mph its turning about 2900 with a 235/75R15 radial (28.7" tall). Joe
#45013 10/21/2003 7:49 AM
Ape, Welcome to the Stovebolt cool
From what I have heard, the combo should work pretty well.
Are you running stock brakes?
#45014 10/21/2003 8:22 AM
ape
Offline
thanks fellers. Yeah,I'm running stock brakes so far. They did fine up 50 mph with the 216. Time'll tell if they're up to the 261 and 65 mph.I plan to putt-putt down back roads with it ,mostly. I'd hate to modify the old truck anymore than I have. It's a real neet piece of rollin history to me.jim
#45015 10/21/2003 8:31 AM
Welcome to the Stovebolt ape ,, yer truck sounds great .
We NEED pictures grin grin
#45016 10/21/2003 8:36 AM
The 261 is a great engine. I have the original 4 speed with 4.11 gears in mine and it feels like it is geared too low, I can haul some pretty heavy loads with it and it doesn't feel like anything is back there at all. It pulls hills really well. I have a 3.08 rearend I am going to put in it. I think you will really like the 3.55 rearend. I get about 18 mpg with the 4.11 rearend so I am expecting a bit of improvement. Let us know how it turns out.
Paint & Body Shop moderator
#45017 10/21/2003 8:43 AM
ape
Offline
Thanks again,fellers. Soon as we get it back together(Dec?) I'll post some pictures. My pal is a guru at body work and made it look like a show truck, which is not what I wanted,really. It's original blue tho. I'm gonna DRIVE the thing,but keep it up for future times. jim
#45018 10/21/2003 8:48 AM
ape
Offline
Hay Dusty, New Zealand ,eh? Have a good day, mate. I'll let you know how my mileage ,etc works out. Idaho Jim
#45019 10/21/2003 8:58 AM
ape
Offline
Hay Dusty, I clicked your link. WHAT A GORGEOUS TRUCK you have ! Beyond handsome. 4onthefloor, I'd be real interested in how you like the 3:08 rearend in your truck. Idaho Jim
