Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Frank50, 55shaker, 1955 1 Series), 48 guests, and 2 robots.
Topics128,006
Posts1,055,272
Members48,418
#449852 09/07/2008 4:03 AM
why cant i get the engine and transmission to separate more than about a half of an inch? i have all of the bell housing bolts off. it's a '72 GMC 401M and 4 speed Allison automatic.
Did you remove the bolts or nuts holding the torque converter to the flex plate?
Grigg
Grigg #449974 09/07/2008 6:05 PM
how do you get to them? it's the big truck/semi type bellhousing and there are no holes to see inside except a small drain hole
Try removing the starter and looking through that hole, or sometimes there's an access plate at the top of the bellhousing. The Hydramatic has something like 26 bolts holding the fluid coupling housing to the flywheel, and the Allison might have somethiong similar. I've got a GMC 401 in my fire truck, but it's got a 5-speed manual trans.
theres no plate on top and i can see bolts through the starter hole but theres no way i could get them out because they don't turn with the flywheel.
Do you have a manual for the truck?
Grigg
Grigg #450132 09/08/2008 4:46 AM
I don't know anything about this setup, but on a conventional rig, car or truck, the input shaft stabs the torque converter and it isn't 100% necessary to pull the converter from the flexplate to separate the combo. You can pull the tranny and leave the converter in place. This might be different for this big truck, or something else could be binding.
Stuart
ok i went add started scraping off more grease and found a little cover halfway behind the oil pan and then took all of the torque converter nuts off, there was 6 of them. then i got on the tractor and started to take engine out and it came about 6 inches then one of the studs on the torque converter caught the flexplate and bent it. it;s not the normal kind, it's about 5 layers of flat metal bolted to the center of the flywheel, do you think i could flatten it enough and have it still work or do i have to get a new one. if i have to get a new one do you think NAPA could get it?
