2 members (54farmtruck, Rich'sToys), 115 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
My 41 chevy 1/2 ton. It had a home brew wiring harness from the P/O along with an updated 350 sb, 700r4 trannie, with tilt steering. ..It didn't have a fuse block. Now that I have it all a part I want to use a modern GM wiring harness that will plug into the steer column, the HEI ignition, lights etc. Can anyone suggest a company that would carry a harness/fuse block with the correct GM pig tails? I'll need ten or twelve circuts, and price is a concern.
there are several out there Dave, I personally went with Ron Francis because it was already purchased and in the tool box from my uncle, but there are a few makers that are a lot less expensive.
Juat a note on Ron Francis wiring it is the cats arse as far as a great fuse block,wiring and customer service..
Its all up to you on whom you select.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Dave, I went with http://www.ezwiring.com/. They do a loom that should cover all the bases. I've not installed mine yet but it looks a total 'no brainer!' The wires are labelled every 5".
I hope this helps. They're also cheaper than Ron Francis as I see cost is a concern.
Jock.
More pix on Flickr.
I got the EZWire kit as well. That's the easiest way to go. Everything you need is all there.
try these guy's there pretty good !http://www.painlessperformance.com/
I bought an EZ Wiring 12-circuit kit for my '50 and have it about 85% installed right now. I'm in the midst of troubleshooting a few circuits (see new post). The kit was pretty straight forward but be ready to do some thinking. The directions aren't great but what do you expect for a "universal" kit. There are extra circuits that I won't use and some circuits missing that I need, so there is some swapping going on right now to get everything sorted out. I drew up my own wiring diagram to figure out where everything needs to go.
Hope this helps.
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
I picked up a Painless wiring kit on E Bay for a good price. Install was OK and they have great Tech Support if you need it.
1940 Chevy KC 1/2-Ton
