1 members (Peggy M), 169 guests, and 5 robots.
Topics128,106
Posts1,056,214
Members48,436
#447182 08/30/2008 4:23 AM
I know this should go in the swap meet but I wanted the big bolters to check it out.
http://portland.craigslist.org/grg/cto/817403457.html
3B Offline
Hy tri5trucking, thanks for the heads up, I've been looking for one of those for awhile.
3B #447235 08/30/2008 12:02 PM
air brakes, spring ride seat. looks reasonably sound
kb3csw #447252 08/30/2008 2:53 PM
Very interesting. I like it. Good price too.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #447480 08/31/2008 6:31 AM
Hey 3B......I Promise not to steal this one from under your nose! grin
Hope Ya get it! thumbs_up
GMC: Get More Cash...
1958 GMC
My Webshots photos
24601
Guys,
Are the engine-mounted air compressors like that hard to find? Could I pick one up at a truck junkyard, or is it more of a quest than that to find one?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Bobb I'm curious what transmission or transmissions it has? Have you talked at all to the owner?
I used to live in The Dalles and if you are headed down to pick it up and would like some help, slow down coming through Seattle and I'll come along.
OldSub #448458 09/03/2008 2:55 AM
3B Offline
Hy OldSub and guys, this truck could be purchased with a 5spd. New Process, a heavy duty Spicer 5spd., or a 6spd. automatic [Powermatic], power would then be transmitted through a 3spd. power divider, with 3 ratios low - 2.22 to 1, intermediate 1.22 to 1 and direct 1 to 1, hope that helps
3B #448467 09/03/2008 3:27 AM
John,
Jackson's has a yard full of them, they are on every air brake truck, however brackets and pulley sized may be different from truck to truck. Gary may have one in his parts pile...
Looks like the 8700 has Air Over Hydraulic Brakes. I'd be all over this truck if it weren't 3000 miles away frown . It would cost more to ship it here than the asking price ohwell
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #448525 09/03/2008 5:49 AM
the compressors are easy to find you can get them rebuilt from napa or a used one from a junkyard. you would have to supply oil feed and a oil drain and make a mounting braket.
I guess you guys know a CDL would be required to drive it and anything that can still be used Commercially is is almost impossible to insure as an antique vehicle. Commercial vehicles are expensive to insure.
Apprentice
Apprentice
The tandem does appear to have air over hydraulic brakes and looks to have a 5-speed tranny because the truck has a clutch pedal instead of a retarder pedal. The retarder pedal has a different shape than the clutch pedal and the retarder pedal rests closer to the floorboard. Very neat truck!!!!
It must be air over hydraulic because it does have hydraulic brake pedal. The air-hydraulic cylinders were a lot of trouble, and are now pretty obsolete.
I don't know about all states but in maryland you can stlll get non commercial license in the same classes as the CDL air brake test might still be required. I would think hobbyist would be able to get one in that catagory if their state offers the non commercial license.
Insurance can be a problem on anything larger than 1 ton antique. Gulfway seems to be the only insurance broker that goes after Antique Commercial Vehicles and their posted policys are much more liberial than some of the other policys. I've heard they are a little more expensive than JCTaylor bout easier to work with.
kb3csw #449334 09/05/2008 6:42 PM
Air brakes is really not the issue. Federal law requires a CDL to drive with a vehicle with a gross vehicle weight of 26,001 lbs or more. There are certain farm exemptions including hauling crops from the field to the market, but a person has to prove he is either a custom harvester or a farmer by profession. This truck would probably have a gvw of 38000 to 44000 lbs. depending on what axles are under it. This is why trucks like this are very cheap. They are really not reliable or efficient for daily commercial use, and they are too expensive to own for casual use.
i never could figure out why there would be an exemption for farmers as farming is a commercial enterprise (other than a powerful farm lobby). i've forgotten all the exemptions but fire fighters were also listed when they first came out with the cdl. I figured state and county workers would be exempt but when my stepfather went to work for the county they required him to get a cdl.
kb3csw #449654 09/06/2008 3:28 PM
This truck should have Chevrolet axles rated at 15k each (if still original) with a GVW of 28,000 and a GVCW of 45,000.
All vehicles with over 26,001 GVW must have a CDL (Class A for trailers and Class B for straight jobs). Only fire fighters and farmers can drive Class A or B vehicle with a Non-Commercial Class A or B license. By law, all of the drivers of these big RV Coach's are also required to have Class B CDL with Air (if equiped).
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
