| | | Forums66 Topics128,052 Posts1,055,718 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | I purchased a 74 nova for the clip and rear end, does anyone know or how figure out if the transmissioin will fit a 350 engine. it connected to a 6 cylinder. it was a 4 door if that helps, had air and power sterring. getting read for my new frame, | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If the transmission was used behind any stock motor available in a '74 Nova it will fit behind a Chevrolet 350.
The '74 Nova front clip is NOT a good choice for your '53 truck.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 |
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | im using a 1/2 ton frame instead, my friend used a 74 and it was a perfect fit. looks gooooood. why you say its not> | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | ok, now that we know that the 350 will hook up, what do i have to do to make it work, flywheel, starter and that type of thing. thanks danny | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | You can use any stock torque converter designed for a TH350. The flywheel will be the same one that you would use with a 350 small block. Just make sure that the ring gear and start teeth match.
Frank
