1 members (Hotrod Lincoln), 73 guests, and 1 robot.
Topics128,055
Posts1,055,782
#448483 09/03/2008 3:57 AM
I purchased a 74 nova for the clip and rear end, does anyone know or how figure out if the transmissioin will fit a 350 engine. it connected to a 6 cylinder. it was a 4 door if that helps, had air and power sterring. getting read for my new frame,
1953 Chevy 3/4-Ton Stakebed
[url=http://fiftythree-chevy-flatbed.tripod.com/
If the transmission was used behind any stock motor available in a '74 Nova it will fit behind a Chevrolet 350.
The '74 Nova front clip is NOT a good choice for your '53 truck.
The TH350 trans will bolt up to a small block chevy (350 CID).
350 CID connected to a TH350 Transmission
350 CID small block chevy and a TH350 transmission
I hope this helps.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
OldSub #448746 09/04/2008 12:32 AM
im using a 1/2 ton frame instead, my friend used a 74 and it was a perfect fit. looks gooooood. why you say its not>
53flatbed #448749 09/04/2008 12:37 AM
ok, now that we know that the 350 will hook up, what do i have to do to make it work, flywheel, starter and that type of thing. thanks danny
You can use any stock torque converter designed for a TH350. The flywheel will be the same one that you would use with a 350 small block. Just make sure that the ring gear and start teeth match.
Frank
