1 members (baldeagle),
53
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | Ok all you kind folks with tons of knowledge, how do you tell a 30's something GM steel spoke/wire wheel from a Ford? Are they maked somewhere?
Thanks in advance. | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | C'mon guys and gals, there has got to be some way of telling these apart. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I can't help, but I bleed for ya. A few weeks agp I asked a question on the dementions of the front frnder braces. I tried two forums and rephrased my question 3 times. I never did get an answer. I kinda thought after 60 plus years someone might of had a fender bender and bent the front fender support. I feel kinda special that after 60 plus years I am the only one who had this problem. As an aside, clean the wheel thouroughly. Look carefully at the wheel. Henry Ford was paranoid about marking every part Ford. Gm did the same in the early years, but not as fanaticaly as Ford. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I am going to stick my neck out here. Fords and 5 lugs on 5" dia. Chevys are 6 lug on 5 1/2 dia. 1929 specs. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The ford wheels just look like ford wheels...  So far that's how I tell, it can be done from quite a distance too. Good to know you can count lugs and figure it out that way too. Grigg | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | I will go through the stack of wire wheels I got in today and try to sort them out.
Many thanks.
Ernie | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 57cameoguy: Well, I came back to this post to add my two cent but I see some others have stepped up to the plate better than I ever could. I was only going to suggest looking at some pics of early vehicles and most FERD products have that little circle on them somewhere. Nevertheless Lonnie has taught us all something. | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | In going through the wheels it appears based on Lonnie's tip, I have 2 complete sets of Fued wheels and 2 CHEVY wheels. Blah! | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Just as a side note, does anyone know when Chevy started using 6 on 5 1/2 lug pattern? The referrence I posted is a 1992 spec. book, so at least to that time. Was this the pattern Chevy started with or was there another wheel attachment? | | |
