1 members (Eisenholtz),
59
Mod | | | Forums66 Topics128,022 Posts1,055,377 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Well I've about had it. I have hit another wall with the TPI conversion. If you recall, I've had issues with the speed sender, heater hose, oil pressure sender & knock sender to name a few. I pretty much handled them all. The knock sender I did locate the drain plug and mounted it there with no problem but it was in the way of my block huggers. So I bought a set of 85 - 92 Camaro shorty headers and thought that would take care of it. WRONG!! It fit perfectly on the drivers side and I'm thinking problem solved, but the passenger side will not fit! #$$^@$*(# #@4(@#$@#$&*@ @#@(*#$@#*&$^^@!!!! AT this point I'm about ready to slap a carb on and be done with it! It would have been running long ago if I had done it in the first place!! **#$&#^^%$%#@(* @($&@#^&^ **&$^^#@%@ ))(*$*@#$&^@ :mad:
Thank you for letting me vent.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Sometimes we need to let it out. You're working in uncharted territory. What if Lewis and Clark quit when the rivers ended?
Keep at it and you will find the solution - usually in the most obvious place. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What if Lewis and Clark quit when the rivers ended? We would all be MobileOrtho's neighbors east of the Mississippi river... How about taking the knock sensor off, choosing the headers that otherwise fit best, and then finding a place where the knock sensor will work? I think the consensus in the thread about that sensor was that it doesn't matter much where it is located.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | How about taking the knock sensor off, choosing the headers that otherwise fit best, and then finding a place where the knock sensor will work? Yeah that's the game plan. Just needed to let off some steam. I'll list the newly purchased headers on ebay to try to recup some funds and try again. I'll start with the fuel pump block off plate.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would tape it into the wiring harness somewhere so it never gets to do it's job but still not set off the "check engine" light, Scott
| | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Trust me, it will fit.
| | | | | Joined: Jun 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 71 | No, no, no. The TPI should be used with all sensors and the knock sensor will fit with block hugger manifolds. I have an '89 TPI on my '62, and all of the sensors work and are connected, the knock sensor is located at the side of the lower engine block water jacket. Give me a call at --- --- ---- and we can talk this through. Trust me, it will fit. I wouldnt post my number that publicly. There are bots for e-mail addresses Im sure there are bots and just messed up people who will take advantage of your number being publicly posted. take it down and send it in a PM
| | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | It was a work number, but thanks for the advice. Will do. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Despite the fact that the V8 conversion is probably the most common modification I see on these AD trucks, it is also a total custom job and an absolute exercise in frustration. I've successfully converted mine and I'm STILL having issues.
Most people use a log manifold for the exhaust on each side because that's about all that will fit in the ridiculously narrow space between the framerails. I was dead set on headers. You can try this as a possibility, and I'll tell you the problems I had.
I bought a set of shorty headers (basically block-huggers) off of a stock '86 Corvette. I turned them upside down and wrapped them real good with fiberglass header wrap. I had to take the stock heat shields off them because no way would they fit with those. So with the headers sticking up in the air, I ordered a set of stock-style ball-type flanges and welded them to J-bends. The J-bends had to have custom sections welded on to clear, but basically, they turn back down in the rear corners of the engine bay. I wrapped those too. From there, the exhaust is a conventional dual exhaust.
The main problem I'm having is heat. Let me re-phrase that...HEAT!!! Even though they're all wrapped, I still have a problem with melting wires. I need some better heat isolation, which I'll work on.
Or, here's another thought. Can you get two different types of headers? Check out the swap meets. My Corvette headers were in beautiful shape and were only $5 bucks for the pair. At that price, you can afford to experiment.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Hot Rod Dad,
Those are the headers I'm using as I'm putting in a 1986 TPI from a 'Vette. Easy to weld on, look good without the shields. Although I could still fit the shields if I want to. Tight fit, but they fit with the Camaro clip.
Where'd you get your "set of stock-style ball-type flanges" from? Thanks! | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I believe I got them from Summit Racing. I just told them '86 Vette ball collector type flanges, in 2 1/2" diameter, and they weren't very much. Then just welded them on my pipes.
800-230-3030
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Talked with Tim K today and got some very helpful advice on solving the problem. Will keep you posted on the progress.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 |
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 |
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Despite the fact that the V8 conversion is probably the most common modification I see on these AD trucks, it is also a total custom job and an absolute exercise in frustration. Or, here's another thought. Can you get two different types of headers? Check out the swap meets. My Corvette headers were in beautiful shape and were only $5 bucks for the pair. At that price, you can afford to experiment. Was able to find an elbow @ Lowes and was able to keep the block huggers. Thanks Tim K for the tip. Only problem know is I have a new set to fit a Camaro. Anyone interested $50 + shipping.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I wonder if being so close to the header might have a heat related effect on the sender.
~Jim
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I don't think it will be a problem. I did however fire it up for the first time today. Sounds great, but still have to run the exhaust.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Naw, the heat from the headers won't hurt it. My IROC-Z had Hooker headers on the 350 TPI and in all those years, the knock sensor was fine.
I kinda wish I kept that car though. It would have been really cool with an LS7 conversion. But I didn't want to deal with the rust issues I was having.
