0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#44643 05/17/2003 11:58 PM
I am putting in a dual power brake unit for drum/drum brakes.
Does it matter which way I hook up the lines (front back)? I figure the pressure was the same front/back in the single system. Right?
if it dosen't need fixed, break it
#44644 05/18/2003 8:28 AM
The front brake is usually the pedal side of the master cylinder.
Paint & Body Shop moderator
#44645 05/18/2003 6:09 PM
I've run into some dual-circuit master cylinders with the front chamber feeding the front brakes. My '77 Corvette is that way, as is my daily driver Talon (a Mitsubishi that thinks it was built by Chrysler).
1954 GMC De Luxe COE
#44646 05/20/2003 12:16 AM
Socket Breaker
Socket Breaker
GMCpanel... a Talon. Now that is Vintage. smile
Heh.
-W
