1 members (baldeagle),
40
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Anyone out there ever come across a 6 cyl "Blue Flame?" If so, anyone know application? Thx
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Blue Flame is the passenger car designation. In a truck, it would be a Thrift Master.
Bill Burmeister | | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Oh, it also has on the valve cover "Blue Flame 140" Is the 140 refering to the horse power? Is it a 235? It is in a 1957 passenger car. What would be the difference from a Thrift-Master and the Blue Flame? | | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | One last question, when did thriftmaster start and finish? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, 140 was the horsepower. It is a 235, and should be a hydraulic cam engine. Generally speaking, solid (truck) vs. hydraulic (passenger) lifters is the main difference, depending on year. Some years, an automatic equipped car would have a different cam and a bit higher compression for more power to make up for losses in the trans. Otherwise, they are essentially the same. According to my research, the Thrift Master name ran from '47 to '62. The Blue Flame name ran rom '50 ('50-'52 on Powerglide only)-'62.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Not all Blue Fame Sixes ran at 140 horsepower, but they were higher horsepower than the Thriftmaster truck engine and the standard automobile 235. As stated by LONGBOX55, the Blue Flame Sixes were put in Powerglide-equipped cars, and all but the Corvette Blue Flame sixes had hydraulic lifters. Here is a Blue Flame 115 and the 1953 Blue Flame 125. Here is a standard 106 hp Thrift-King 1953 automobile 235.The 1955 Blue Flame Sixes in automobiles (not Corvettes) produced 123 or 136 hp. The 1953-55 Corvette Blue Flame Six had mechanical lifters and produced up to 150 hp. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks for this thread and information.
As I looked at the throttle linkage it is different from what I have. I believe that I may have bought and will put one of these engines in my 55 2nd. I need to find the swing arm between the push rod from the gas peddle and the vertical rod up to the carburetor.
I need to put this request in the parts wanted section. Can anyone help me with description?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 140 is the correct hp spec for a '57 Blue Flame. It's also the hp spc for the Thriftmaster version as well.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Thank you all for such great info and photos! Wow, this site is great. Ask, and you receive! Excellent! | | |
