3 members (Bill Hanlon, 59 fleet, klhansen), 117 guests, and 2 robots.
Topics128,182
Posts1,057,260
Members48,467
How hard is it to remove the fenders and cab off of a 53. THe easiest for one person removing all of the bolts. how much does the cab weight with no fenders attached.thanks. ive tried searching but get so many threads it takes so long to find what im looking for
1953 Chevy 3/4-Ton Stakebed
[url=http://fiftythree-chevy-flatbed.tripod.com/
Use a cherry picker / engine hoist / shop hoist, etc. for removing the cab. You will also need a 6' long section of 2x6. Then one guy can put a cab on and off at will. Also works for boxes, engines, etc.
Cab weighs about 250-300.
I'd say that 250-300 lbs is pretty close for a stripped cab, no glass seats, gas tank or doors. With a couple 2x6's and four guys you can easily lift the cab off the frame.
Unless you are going to disassemble your truck for restoration, the entire front clip can come off in one piece.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Hey 53, I just did my second cab and it's really easy. Here is a picture from yesterday. I had made an extension arm which goes in the end of my engine hoist. I got lazy and didn't want to put it in so I got a 2x6 and beefed it up with a 4x4 in the middle. I put it as far forward in the door openings as I could and it balanced perfect. It was so easy, I'm going to make a better version of my quickie lift mechanism. And yes, I removed the cab alone!
Bruce
My Trucks
Stuff I Collect
The best way to remove the cab is to just grab your wrenches and start busting knuckles. Be sure to get a factory assembly manual,
It's good for disassembly as well as assembly.
Last edited by cletis; 08/25/2008 3:39 AM. Reason: removed another Ebay link from one of your posts. It's getting old.
~Jim
U
Apprentice
Apprentice
U Offline
55 First Suburban... Why didnt I think of that? Great idea! You need to make up a bracket swivel thingy and market it.
I suffer from ADAD (Advance Design Acquisition Disorder)
All in a day's job for a moderator! Keeps you on your toes Cletis!
~Jim
I know, it's really simple! I'll be welding up a mount and support system soon. I'll post pictures for everybody when I do.
Bruce
My Trucks
Stuff I Collect
go to the tech section and see my cab hoist it cost about 100.00 and a few hours to build, some have made comments it doesnt look safe but i lifted an entire truck with it and have removed sevaral cabs. my hoist also allows you to just remove the steering wheel and column shift lever and roll the rest of the cab out from underneath. it is also very handy when putting back together. i did mine after it was painted and had no problems. Paul
