Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Gdads51, Stewart2, Otto Skorzeny, 1 invisible), 85 guests, and 1 robot.
Topics128,292
Posts1,058,598
Members48,492
Anyone got seats that lent themselves well to the Task Force models? I.E simple fabrication etc..
Keith
Can't say much about that model of truck, but I'm working on a 63 for my Sis and found a pair from a Plymouth Neon that are going to work great with very little work. Get the chance to browse through a salvage yard and find something you like, and most likely you'll be able to make them work easily enough. These trucks(all models and years) are very forgiving to about anything you can come up with to make it yours. Good luck.
dj durant
More pix on Flickr
caravan buckets ..have some if interested see parts for sale
I used '89 S-10 buckets in my '57 GMC,just cuz I had 'em and the stock seat was trashed. Comfortable enough,but a real hassle to install. The sliders are not at all concentric,so each hole had to be drilled specifically,and had to be lifted about 3 to 5 inches to get the seats leveled. I don'r recommend 'em if you have any other options open to you.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
I have 2002 Chevy Silverado seats in my 57 TF, but getting ready to go back to stock. The seats fit great with only 4 holes required. I also like that the seat belts are integrated in the seat. Very comfortable....The only reason I am swapping is that I am 6'4" and the seats are thick so I am a little crowded. I also could not fit in the small center seat, just the buckets.
Moderated by  ndkid275, Phak1
