1 members (LAROKE), 127 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,471
It is known knowlege that trailer wheels will fit our 8 lug hubs while clearing tie rod ends. However after searching last two years I had difficulty finding non-spoked trailer wheels or any that looked like the originals.
Finally I hit the Jack Pot.
My uncle had a older trailer which had the wheels I wanted. So I tried to fit them and it worked.
Moderator's note: All the links previously in this post are dead. The info has been reposted with good links on page 2 of the thread.
I hope some body can use this info. I know that wheels on this application is a contant problem. Thought I would share my good find.
Thanks every one for you help.[color:#3333FF][/color]
You did a great job of documenting this. Two of my rims are these very ones. I also used bulge nuts because the holes are larger than the originals. You may have noticed that they have baby moons on that site which look similar to the original hubcaps. I thought that the moons with a GMC transfer might look pretty authentic.
1951 1 Ton Completed
Thanks for all of the great information--just what I have been looking for. I will be glad to get the spoke wheels off of my truck. I appreciate the good advice and all of the hard work on the great pictures...T.K.
Special thanks to Shellology.
Looks nice! sadly I had some of them rim's i would have given away. . .
the tire's you picked are ok. . .
they don't get that good of traction tho
Be very carful of where you drive it. . .
I can get 235/85R16 LR-E and 7.50-16LR-D in highway tread for your steers. . .
I can also get 235/85R16 LR-E and 7.50-16LR-D in snow grip's and Mud traction's for your drives. . .
grin :p grin
It's the 19.5's i can't find in the Grip's or traction's anymore . . . :mad: :o :mad:
1962 GMC K3000, GMC-379 V6.
1951 3800
-hotshoe
Truckernix, I didn't notice those hubs at first but your right that look o.k.
Thanks for the advice on tires, hopefully that want be a issue. Im thinking that this trucks days of driving amongst inclement conditions are likely over.
I'm gonna hold off on the new tires anyways, because the truck is still years from driving on the road and I don't want them obtaining bad spots or becoming dry rotten before I really need them. I will be adding used cheeaappp tires that atleast hold air instead. This way I can move Loy around the yard.
Junior Member
Junior Member
I had a problem with rims also for my 1950 3600. A parts guy at my local parts store just happens to be restoring a 50 also. He has white wagon wheels on his. Ordered the same looks good
At long last I have new radial tires on my 1950, 3604. All the suspension and brakes are stock on mine. Quite a difference in the ride, the bad vibrations in the front end are gone and with the windows down I can’t here any tire noise. I had to settle on 9.50R 16.5 for the rear and 8.75R 16.5 for the fronts. A little fat but their tubeless radials all around at last.
The wheels are 16.5’s from a 1980 C20 and fit the rear with plenty of clearance. The fronts needed a 1.25” spacer/adapter, which provides close to an inch clearance. I probably could have gotten away with a 1” spacer/adaptor but any less wouldn’t hide the stock lugs.
The Clips are from the venders and needed a 3/8” stand off to grab the stock hubcaps. They look durn near stock and you have to get up close to tell their not. Here’s a few picks that show them on the truck: http://rides.webshots.com/photo/2513755820098611668CgdlbK
Denny Graham\
Sandwich, IL
Denny G
Sandwich, IL
Denny, those do look good. I hope mine "wheel" to when I get it done.
Becareful running wheel spacers, most drag-strips want allow them. Just incase you do plan on racing your truck. haha
Thank you Shellology, this is also what I've been looking for - rims with clearance for the 3600!
tk261 in Denver - save on shipping, there's a Redneck Trailer Supply in Frederick, off highway 52 and I-25, see their catalog, they have the same rims Shellology describes, the 17-153's. They have branches all over the country:
http://www.redneck-trailer.com/locations.htm
A update to a couple inquires:
Sorry for the delayed report. You can check out my latest pictures on Webshots and that's where my project has paused. A truck frame that can move under its own power.
The wheels are working fine. Although, I went with a different tire purchased only at NTB (National Tire and Battery) which was only about 82 dollars a piece and were tall and skinny like I wanted. While I was there, I got them to go ahead and mount them. The "kids" working there seem to have alot of trouble balancing them but still got the job done. Unfortunately I have not driven the truck on the road at higher speeds so can not give any more information about how well their doing.
One suggestion would be to call the the trailer rim place and
1. Have somebody visually verify all the rims are there.
Afraid if one rim came from different warehouse it might be different.
2. Ask what do they look like. (I did not want spoked)
Otherwise as stated they fit; barely cleared the tie rod and seem to work just fine.
I went to the local trailer shop 6Roblees. They have the rims, but said the weight rating was less than truck rims 3600 pounds I think it was on the trailer rim. I don't know the weight rating of a truck rim. Also the trailer rims come in two lug hole sizes so make sure you get the right one. I have dug through many piles of used rims and have found two that work on the front I don't know what they were on originally. At one time I found a dodge rim that fit perfectly, too bad it was bent. Are these trailer rims safe for driving off road?
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
hey,thanks for the wheel information. Red Neck trailer supply is on my way back from St.Louis next week.Pickin up a complete bed with fenders for my 50 3/4 ton.should be a productive road trip
Thanks Again
Jimmy Gatz
thanks for the info.
i recently mounted a set of oem trailer wheels and radial tires to match. i got them through my local mom and pop wheel and tire outfit. they gave me a great price. they also let me do all the labor of mounting the tires on the rims and balancing them. that saved me a few extra $.
anyway, they work but the clearance is very tight. so tight that the wheel weights on the inside of the rim rub on the tie rods. simple fix. i just popped the weights off. the wheel does not feel out of balance while driving. if it does i'll use the stick on weights and place them closer to the centerline of the wheel.
thanks again for the info. my split rims were going to need some major work to be safe.
When I had my wheels balanced, I had them use tape weights on the inside. They don't interfere at all.
Please be careful when buying these rims from Rednck trailer supply!!!!! The center hub hole on these rims is 4.90 inches
The factory rims are 4.75 inches. If you don't cut filler adapters for this hub gap You run the risk of shearing off the studs!!!!!!!!!!!!!! Luckily have a machine shop at work.Also you have to use the .50 inset,with3 1/2 inch backspace to clear the tie rod ends.Hope this helps all the 3/4 ton hub'ers.Look at the wheel mounted on the truck and you'll see what I mean.You have to make the picture FULL Screen to see the hub Gap
Jimmy Gatz
The trailer rims that were discussed before do not require a spacer and they are not hub centric. The rim is not supported by the hub at the hole, even with the originals.
I found some rims similar off a Ford van. They fit fine and dandy.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I drug this old thread back up to let ya'll know that this setup with the 16x6 wheels and LT235/85R16 tires works great on my daughter's truck. I just used the matching trailer hubcaps and applied the red CHEVROLET letters.
As an added bonus, it steers MUCH easier than it did with the 15" 60 series tires that were on the original rims. The wheels and tires were a birthday present and I put them after the kid went inside for the evening. In the manner of a high school girl, she just jumped in the truck in the morning and went to school without noticing a thing. She called when she got there and asked if I had installed power steering! Kids...
Mike
1953 3600 350/700R4
I have there and done that and posted my experience, which has been excellent. Check it out, and let me know if you have any questions. Lots of pix and how to do the hubcaps, too.
Harry
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=748601
Moderated
Moderated
Hey shellology just joined I've been looking for wheels for my 3600 pain in the rear thanks for the info. Problem is web site for them is down and can't find phone number for them for the life of me can anyone help...
Maybe etrailer.com can help you.
I have bought a lot of wheels from these guys.
http://www.southwestwheel.com/store/p-432-109292t.aspx
They work fine on the old GM 8 hole.
Sorry guys I have been on hiatus for a very long time. Looks like my pictures are all gone as the webshots site I was using has changed. Darn...
I know this thread is very old, but do you guys swap hubs to run different wheels?
I have decided to update this post and it's pictures after many years.
As previously discussed some trailer wheels will fit our 8 lug hubs while clearing tie rod ends. Originally I had difficulty finding non-spoked trailer wheels or any that looked similar to the originals.
My uncle had a older trailer which had the wheels I wanted. So I tried to fit them and they worked.
http://s522.photobucket.com/user/Sh...06_zps2b199962.jpg.html?sort=3&o=299
Even the hub caps appear to fit if I order new clips.
http://s522.photobucket.com/user/Sh...04_zpsfdd7e77f.jpg.html?sort=3&o=301
You might can get them from this site which appears to have a large catalog. http://www.redneck-trailer.com/
The site I used is no longer available but I ordered the 16 x 6, 8 lug wheels (A-17-153-65), and was several options that might work.
The price was $62.75 per wheel.
I ordered 5 so I could have a side mounted full size spare.
http://s522.photobucket.com/user/Sh...12_zps34fda049.jpg.html?sort=3&o=293
http://s522.photobucket.com/user/Sh...11_zpsbc51f786.jpg.html?sort=3&o=294
Shipping was $89 dollars and only took the 2 days to deliver to my door step.
Total price was $406.14 which I thought was good compared to other options.
The wheel came in black gloss which is what I wanted and looked very similar to stock split rims
http://s522.photobucket.com/user/Sh...18_zps3d6d2607.jpg.html?sort=3&o=287
Best part is that this wheel has 3.5 backspacing which clears tie rods with out spacers needed, barely.
http://s522.photobucket.com/user/Sh...05_zps5a86202a.jpg.html?sort=3&o=300
http://s522.photobucket.com/user/Sh...14_zpsbcff2bc5.jpg.html?sort=3&o=291
The tire I ended up using was a Mesa A/P LT 235/85R16
Load Range E
The tire shop seemed to have trouble balancing the wheels but finally got them done.
After near 10 years I have finally driven my truck on the road to see how it would handle. And the verdict is...Good. No noticeable problems with the handling, that's not attributed to being just an old truck.
http://s522.photobucket.com/user/Sh...0601_zpsyuxvbjti.jpg.html?sort=3&o=7
Hope this can be a help.
That is some mighty good and detailed info for the 8 luggers among us. Thanks for the report.
Shellology,
I can't seem to view your pictures on webshots also the link to lowcosttrailersupplies is sending me to a weird domain site? I need wheels for my 1946 3600.
All the dead links have now been deleted. The info with good links is reposted three posts before this one.
Redneck Trailer Has the trailer wheels as well. I purchased my rims there fairly reasonable. There catalog has lots of info as well. Have fun and good luck
Dan
