8 members (Gdads51, frogfarmer, Wayne67vert, sron48, dt235sd, cmayna, Scott, 48jim1ton),
128
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#4438 07/20/2003 10:15 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | my 52 halfton has a 54 yr 235 eng, would the water pump be the same for a truck 235 and car 235?...thanks........Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#4439 07/20/2003 10:31 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | If the pulley width is the same, it should be.
#4440 07/20/2003 11:21 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Guess I should determine if I have a truck or car eng then cause I do not know what to compare the width with, Hold on, let me check with my Jim Carter's book, looks like 41 to 52 has 3/4 inch pulley and 53 to 55 has 3/8 inch so I would bet that mine is 3/8 inch, it is only about 102 so I will check later,,,I keep forgetting that I have his book around..thanks....Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I like having books with good info in them. It keeps me from trying to cram all that info into two cells
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I agree but sometimes it is quicker to post on the bolt for expert advice then it is to find the book.(at least for me)......Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Didn't the car have a longer pulley shaft than on AD truck engines? Or, was the longer shaft for both cars and trucks from '55-'62?
Tim | | |
#4444 07/22/2003 12:30 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Tim, in Jim Carter's book, he states that his short shaft to be used when installing a 55-62 235 eng in 37 to 55 chevy trucks. ,eliminates the need to move the radiator forward and has the 3/8 grove as required for the correct pulley,so I dont know if his is from a car or not, looks like it is? his longer one is $75 for my truck and the shorter shaft is $93.45, I am still confused, is this short one a special design from him or is it a car one.. and , guess I need not worry because his short one is for a 55-62 eng and my is a 54 -235 eng, I did not know their was that much difference,,oh well,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2003 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 68 | Joker, I just installed a 1954 235(truck engine) in my 1953 3100. No problems. If this helps any. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The standard water pump on the 54 will work. The pulley is separate, comes off when you remove the fan bolts. You should be able get a rebuilt pump at your local mom & pop parts store, if you need one. Should be far less than $75.
The 54 and early 55 235 have the water pump in the same location as the 216. Pump was moved in 55, and the engine compartment was lengthened. The "short shaft" pump being sold is to fit a 55 & later 235 in a 216 bay.
You now either understand or are completely comfused!
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | [img] http://photo.starblvd.net/guitarzan/1-1-1.jpg[/img] This is what a '62 261 (235 is similar) looks like in a 1950 truck engine bay. The pump is an original that I shortened with a press and grinder. The pulley is a fomoco one that I took off a junkyard truck. It bolted in perfectly. I run an electric fan, but there is a small amount of room in there for a mechanical fan if you want to. The radiator and motor mounts are in the stock location.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Fred T and four on the floor, thanks, I really do understand now......Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
