4 members (Otto Skorzeny, Gdads51, Wayne67vert, tclederman), 134 guests, and 1 robot.
Topics128,037
Posts1,055,580
#4438 07/20/2003 10:15 PM
my 52 halfton has a 54 yr 235 eng, would the water pump be the same for a truck 235 and car 235?...thanks........Fred
Redryder pix
My Hotrod
#4439 07/20/2003 10:31 PM
If the pulley width is the same, it should be.
#4440 07/20/2003 11:21 PM
Guess I should determine if I have a truck or car eng then cause I do not know what to compare the width with, Hold on, let me check with my Jim Carter's book, looks like 41 to 52 has 3/4 inch pulley and 53 to 55 has 3/8 inch so I would bet that mine is 3/8 inch, it is only about 102 so I will check later,,,I keep forgetting that I have his book around..thanks....Fred
Redryder pix
My Hotrod
#4441 07/21/2003 1:09 AM
I like having books with good info in them. It keeps me from trying to cram all that info into two cells grin
#4442 07/21/2003 1:17 AM
I agree but sometimes it is quicker to post on the bolt for expert advice then it is to find the book.(at least for me)......Fred
Redryder pix
My Hotrod
#4443 07/21/2003 5:24 AM
Didn't the car have a longer pulley shaft than on AD truck engines? Or, was the longer shaft for both cars and trucks from '55-'62?
Tim
#4444 07/22/2003 12:30 AM
Tim, in Jim Carter's book, he states that his short shaft to be used when installing a 55-62 235 eng in 37 to 55 chevy trucks.
,eliminates the need to move the radiator forward and has the 3/8 grove as required for the correct pulley,so I dont know if his is from a car or not, looks like it is? his longer one is $75 for my truck and the shorter shaft is $93.45, I am still confused, is this short one a special design from him or is it a car one.. and , guess I need not worry because his short one is for a 55-62 eng and my is a 54 -235 eng, I did not know their was that much difference,,oh well,Fred
Redryder pix
My Hotrod
#4445 07/22/2003 3:08 AM
Joker,
I just installed a 1954 235(truck engine) in my 1953 3100. No problems. If this helps any.
1953 Chevy 3100
The Green Truck
#4446 07/22/2003 3:44 PM
The standard water pump on the 54 will work. The pulley is separate, comes off when you remove the fan bolts. You should be able get a rebuilt pump at your local mom & pop parts store, if you need one. Should be far less than $75.
The 54 and early 55 235 have the water pump in the same location as the 216. Pump was moved in 55, and the engine compartment was lengthened. The "short shaft" pump being sold is to fit a 55 & later 235 in a 216 bay.
You now either understand or are completely comfused!
Fred
52 3600
69 C-10
#4447 07/22/2003 6:05 PM
[img]http://photo.starblvd.net/guitarzan/1-1-1.jpg[/img]
This is what a '62 261 (235 is similar) looks like in a 1950 truck engine bay. The pump is an original that I shortened with a press and grinder. The pulley is a fomoco one that I took off a junkyard truck. It bolted in perfectly. I run an electric fan, but there is a small amount of room in there for a mechanical fan if you want to. The radiator and motor mounts are in the stock location.
Paint & Body Shop moderator
#4448 07/22/2003 9:23 PM
Fred T and four on the floor, thanks, I really do understand now......Fred
Redryder pix
My Hotrod
