2 members (moparguy, 51sub),
103
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 23 Apprentice | | Apprentice Joined: Aug 2008 Posts: 23 | My 55 1st series has 6 lug wheels...are wheels for it readily available or do I have to buy special vintage re-makes? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The pattern is 6 x 5 1/2", same pattern was used on 2wd 1/2 tons up to '70, and on 4x4s up to '87 in wheels that will work. As long as you keep it at a 3 1/2" backspace, wheels for a pre-'87 GM 4x4 will work. You will have to remove the rivets that hold the drom to the front hub to allow the wheel to seat up properly.
Bill Burmeister | | | | | Joined: Aug 2008 Posts: 23 Apprentice | | Apprentice Joined: Aug 2008 Posts: 23 | | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Lets not forget Toyota Land Crusers. Lots of trucks and utility trailers have 6 lug wheels. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Got to be carfull when you get into those import truck wheels, they run a different backspace, and will rub the drag link on a left turn. Which reminds me, make sure to specify the backspacing and that it's for GM truck. Some wheel outfits will substitute a wheel for an import truck if you go with a narrow width. Been there, done that (not on my truck, but on a customers truck). And, yes, the full size Jeep J10 and the full size Wagoneer/Cherokee from the mid-'70s to '92 wave the same patter and backspace.
Bill Burmeister | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | If you are considering custom steel wheels, the back space can be set to what you need. That is within the limits of the wheel. A lot of the truck vendors list custom wheels, but they do not offer custom back spaces. The custom wheel manufactures offer custom back spaces. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Wish you lived closer. I just changed from just what you want. | | |
