5 members (1955 1 Series, mason86, Wayne67vert, Peggy M, Hotrod Lincoln), 85 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#443491 08/20/2008 2:10 AM
Apprentice
Apprentice
My 55 1st series has 6 lug wheels...are wheels for it readily available or do I have to buy special vintage re-makes?
The pattern is 6 x 5 1/2", same pattern was used on 2wd 1/2 tons up to '70, and on 4x4s up to '87 in wheels that will work. As long as you keep it at a 3 1/2" backspace, wheels for a pre-'87 GM 4x4 will work. You will have to remove the rivets that hold the drom to the front hub to allow the wheel to seat up properly.
Bill Burmeister
Apprentice
Apprentice
Thank you!!!
also older jeep rims have the same 6 lug pattern
http://www.stocktonwheel.com/light_truck_wheels.htm
Jim & Caroline
Lets not forget Toyota Land Crusers. Lots of trucks and utility trailers have 6 lug wheels.
Got to be carfull when you get into those import truck wheels, they run a different backspace, and will rub the drag link on a left turn. Which reminds me, make sure to specify the backspacing and that it's for GM truck. Some wheel outfits will substitute a wheel for an import truck if you go with a narrow width. Been there, done that (not on my truck, but on a customers truck).
And, yes, the full size Jeep J10 and the full size Wagoneer/Cherokee from the mid-'70s to '92 wave the same patter and backspace.
Bill Burmeister
If you are considering custom steel wheels, the back space can be set to what you need. That is within the limits of the wheel. A lot of the truck vendors list custom wheels, but they do not offer custom back spaces. The custom wheel manufactures offer custom back spaces.
Wish you lived closer. I just changed from just what you want.
