0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | 1962 Chevy with a 235... I have a new radiator with a 7# cap. I have a new thermostat with a new water pump and all new hoses. I flushed the engine out before replacing all components and filling with 50/50 antifreeze. The belt is tight and I do not over heat. Yet occasionally I will get a small amount of radiator fluid out of the radiator cap hose when I first drive it. I can hear a gurgling noise like a boiling sound then I get the fluid out. AFter that it is fine and it does not leak anymore and does not make a noise. It seems to only happen after it has sat for a while and completely cools down. Thanks Tom | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | maybe it is to full...........
have a question for you, I sold my red 52 chevy truck about 19 months ago to a guy that lives in Tulsa..
I would like to try and get in touch with him, I remember his last name being Griffin and he worked at a rental type place.. he bought redryder from me ( see my website)
if you can be of any help, I would appreciate it.
welcome to the bolt Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe yer filling it too full, should be 1/2-1" below the neck opening - the noise will likely be the water coming from the engine as the stat opens and the hot water meets cold
Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | that was what I meant.... mine use to do that because I always thought it should be full and to the top.........not true as red stated Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | I just checked the fluid and I put a half a gallon in and it did not fill it. That was the second half since last weekend. I check the compression and have 140+ on all cylinders. I think I am losing fluid somewhere but there are no leaks, no overheating and no white smoke. | | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | Joker can you give me a little more to go on with the guy. Tulsa is fairly big but I will help if I can. | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | I'd say there must be a leak someplace,no white smoke...hmmmm How long running does it take to get low?I'd say head gasket,even though comp is good it still could be.Check the cooling systym with one of them cooling systym checkers,pull the plugs and listen in the cylinder's, you may not hear it with the coolant in you may have to drain it, but first check with the fluid in and look for external leak's.Let us know how it turn's out, a slow leak can be sometimes hard to find
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Tulsa, that is all I remember, believe he worked at a rental place for equipment..
getting back to your truck, I am sure this may not be the problem but it wont hurt to check,,,,,,,,,,make sure you do have the radiator cap on tight..........seems strange that it would lose that much coolant and not show the temp heating up...
usually with fresh 50/50 coolant you can find the external leak real quick, either see it or smell it...
you have replaced and covered most ever thing it can be, unless the timing is off, I have never seen this happen myself but folks say it can...
make sure the radiator peacock is tight..
let us know when you find the problem.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | 1962 Chevy with a 235... I have a new radiator with a 7# cap. I have a new thermostat with a new water pump and all new hoses. I flushed the engine out before replacing all components and filling with 50/50 antifreeze. The belt is tight and I do not over heat. Yet occasionally I will get a small amount of radiator fluid out of the radiator cap hose when I first drive it. I can hear a gurgling noise like a boiling sound then I get the fluid out. After that it is fine and it does not leak anymore and does not make a noise. It seems to only happen after it has sat for a while and completely cools down. Thanks Tom OK I am having the same problem....I do not have a new radiator but it has been up to now, working well. I do not overfill it and there is no white smoke. I replaced the freeze plugs and even installed and elect. fan to assist in cooling in this HOT Texas weather. I went out just about one hour ago and noticed the water in the radiator was way way low I put in a gallon and a quarter (to get me home) of water. What should I do next? HELP Cliff549 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | do you have a fan shroud? if not, get one
and consider if maybe that electric fan is more of a hindrence than a help - with electric and stock both, you're more likely to be impedeing air flow than increasing it
Bill | | | | | Joined: Jul 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 93 | Try a higher pressure radiator cap. | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I sure hope you are keeping an eye on "signs of oil in the coolant" and "coolant in the oil".
Did you have this problem prior to replacing all the components?
How many "starts" or trips does it take for it to lose the half gallon?
What is the overflow doing? The pressure should be released through the overflow, not blowing at the cap. Try putting a catch can under the overflow hose so you can see what might be lost through that route.
I think a pressure test "cold" and "hot...warm" would be in order. Although, you mentioned it doesn't overheat, does the temp gauage flucuate or stay steady on whatever the normal running temp reading is?
It seems to me a "spotting on the radiator" wouldn't equate to a half gallon + in a week. Good luck. | | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | I think I found the problem....I bent the tangs on the radiator cap inward to get a better seal on the cap. I think that may have been most of my problem. I went about 50 miles the other day and the level has stabilized. I went out on a short trip to a vintage car rally and it held fine.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | there you go, ever thing is better when it is tight. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2008 Posts: 34 Apprentice | | Apprentice Joined: May 2008 Posts: 34 | Do you have a coolant recovery tank if not it could be going out the over flow while your driving Paul | | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | Yes!
I made a make shift one out of a Fantastic plastic bottle. There was not anything it this last go round. I think the needle nose plier job I did on the cap tangs did the trick. I bent them in and into the under side of the cap to make a tighter seal. | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | do you have a fan shroud? if not, get one
Bill Hmmmmmm I might need to investigate this! thanks Bill. Cliff59 | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Try a higher pressure radiator cap. How much? 14#? Cliff59 | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Yes!
I made a make shift one out of a Fantastic plastic bottle. There was not anything it this last go round. I think the needle nose plier job I did on the cap tangs did the trick. I bent them in and into the under side of the cap to make a tighter seal. Hey Tulsa, I think that I am going tot do that this weekend and see If I can figure out the problem. I also will look into making the cap tighter. Cliff59 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Cliff - a stock 59 rad won't tolerate a 14# cap for long, and the stock engine doesn't need it .... 7# max
Bill | | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | Just a follow up on the radiator I just put 150 miles on the truck today. 90% highway and the rest in town. The radiator held just fine. I do have the 7# radiator cap. By the way I got 14 mpg and have not touched the carb or performed a tune up yet. I hope to increase the mpg when I do. Is there anyone getting 20mpg with a 235? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | one thing to check, drain the coolant down so you can see the tops of the core and shine a light in and see if the tubes are clear. when you flushed the engine you may have loosened something and plugged the core.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | OK! this holiday I went ahead and just made the 7# cap tighter. I also replaced the coolant and went to AutoZone and bought one of those "over-flow bottles"  this may help! Thanks "Tulsa" for letting me gain some insite on the radiator spotting thread!  Regards Cliff59 | | |
