Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (UtahYork, 66flea, 50Chevy3100), 168 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
Greetings folks,
How do I remove the stick shift from my New Process 540C 5-speed manual transmission?
There is a pin on either side of the ball where the stick enters the top of the transmission case, but they don't seem to want to pull out too easily. I'm assuming they are some type of retaining pins???
Please advise so I can yank the tranny and engine this weekend grin grin
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
Push down on the "ball cover" type thing and turn. Thats how i got the shifter out of mine.
Riding in the Passing Lane
Mcdaddy is right. Use a channel lock pliers
push down & turn 1/4 turn counterclockwise.
1972 Chevy c10 Cheyenne Super
MacDaddy,
Worked like a charm grin grin grin
Thanks pal!!!
Burgie
