| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | Anyone know if the pushrod in the front of the master cylinder (the one that connects to the brake pedal) is supposed to have a slight bend in it? (it is the stock master cylinder also)
1965 chevy c-80 409 5-2 20000 original miles. 1965 chevy c-60 348 5-2 single axle tractor. 1952 chevy p/u 235 4 speed restored. 1965 chevy c-60 couch. One grouchy wife. FOR SALE....CHEAP!!!! The future is not what it used to be..... Have a new pair of metric vise-grips and large metric hammer, can fix anything...
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | For me personally I have never worked on one that had a slight bend in it. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The rod should be straight. Bent rods bend easier than straight rods. I know someone will have a situation that used a bent rod and it worked for 100,000 miles, but I have never seen one. The rod should also be as short as possible. If it needs to be longer because of relocating the MC; the rod diameter needs to be larger than stock for added stiffness. | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Did mine last week...straight!
Keith | | |
