1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#443442 08/20/2008 12:40 AM
Anyone know if the pushrod in the front of the master cylinder (the one that connects to the brake pedal) is supposed to have a slight bend in it? (it is the stock master cylinder also)
1965 chevy c-80 409 5-2 20000 original miles.
1965 chevy c-60 348 5-2 single axle tractor.
1952 chevy p/u 235 4 speed restored.
1965 chevy c-60 couch.
One grouchy wife. FOR SALE....CHEAP!!!!
The future is not what it used to be.....
Have a new pair of metric vise-grips and large metric hammer, can fix anything...
For me personally I have never worked on one that had a slight bend in it.
The rod should be straight. Bent rods bend easier than straight rods. I know someone will have a situation that used a bent rod and it worked for 100,000 miles, but I have never seen one. The rod should also be as short as possible. If it needs to be longer because of relocating the MC; the rod diameter needs to be larger than stock for added stiffness.
Did mine last week...straight!
Keith
