0 members (), 78 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#442656 08/17/2008 5:54 PM
I may be buying a 63 C20 from my work soon. It was taken in trade, and it's not wanted. I gave it a brief look-over, and it appears to be solid. The rain gutter does not appear to have any rust in it, but I had a brain fart and didn't look at the fenders/rockers and cab corners. It has a late 6 230/250 and SM420, probably 4.56 gears from what I've read, and a stake bed. What else should I be looking for? I've always liked the 62-63 bodies with the small hood and wrap-around windshield. I just don't know the series real well.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
55 tractor #442686 08/17/2008 8:29 PM
3B Offline
Hy 55 tractor, check out the front end as well, the early 60s used torsion bar suspension setup 60-63 I think. The ball joints that they used are getting HARD to find, hope that helps
3B #442741 08/18/2008 12:04 AM
63 is conventional up front. For the body, check above the windshield on the "brow" for rust, lower rear part of the front fenders and the radiator core support where it attaches to the frame. These are always bad but have replacements available,
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #442762 08/18/2008 1:17 AM
I have a 63 C20. Think you already know the bad areas, but as 48bigtrucks says check the windshield brow. I've had mine now for almost 10 years. The only problem I had was the 292 cracked the block between 3 & 4, letting oil into the water. Check your 230/250 side covers, if 6" high it's a 292. I'm in the central valley if I can help let me know.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #443639 08/20/2008 1:00 PM
Socket Breaker
Socket Breaker
a few tips to poke around and check out:
http://www.stovebolt.com/techtips/buyers_guide_60_66.htm
Woogeroo #444457 08/22/2008 5:45 AM
Thanks for the links and info guys. Haven't heard back yet, amy be a few weeks. Like to have it, crtainly don't need it.
Devin
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
