7 members (Otto Skorzeny, Phak1, TUTS 59, Hotrod Lincoln, Gray_Ghost, Crimson48, 1 invisible),
134
Mod | | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | I've a re-built 235-mid to late 50's. Mechanically sound. No leaks or smoke...I've notived for years that if I start it in the garage by the time I drive it out of the garage, the garage has a strong exhaust smell...lasts for hours..on the other hand..the wife starts her Cherokee in the garage every morning and theres no smell. Don't plan on trying to stop it..just curious why. Age doesn't explain it. How about yours?
Thanks Keith
| | | | | Joined: Aug 2008 Posts: 3 New Guy | | New Guy Joined: Aug 2008 Posts: 3 | your smelling the difference in 50 years of technology.
so...yes,age does explain it. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | They tend to ruun a little fat on startup, todays gas just doesn't burn very well in the older engines.
Bill Burmeister | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The first few minutes that an engine is running are generally the dirtiest. In the choked mode the engine is running over rich, and is not able to burn all of the fuel the carburator is delivering. Also, until the engine warms up the atomization is not complete, causing an over rich condition.
Age is factor, the carburator is forced my design to operate under the mechanical constraints of jets and other conditions all of which are governed by the carburators "tune" as well as the engines condition. Your wife's late model Cherokee has all of the operating ranges of the engine governed by a computer, that can make much more precise adjustments based on sensors. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If by strong "exhaust" smell you mean it smells like old rusty pipes then you need to take it out on the highway and get her up to SPEED and blow the dust out of it. I have seen old exhaust systems have that "exhaust" smell time and again. If you have replaced the exhaust system then you can probably disregard this post...... | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Thanks Guys..I guess this means you've smelled it also..I had a 67 firebird up to about the early 90's..most of the floorboards were gone and my clothes had the same smell when I gout to work..
Anyway way..it's a burnt gas type thing..pungent and lasts..I only run a few minutes at this point so the plugs do show a sooty burn-
AChip-never know you could be right..I have a set of NOS tube headers from Clifford..if I they'll fit. Original application was a 57 chevy 235..may need surgery, don't know yet ..but hopefully new headers/pipes in the near future..
Thanks...Keith
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Most of the stench actually comes out of the road draft tube. A vehicle with PCV smells so much cleaner!
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | There's something about the "old stink" that I go nuts over. Whenever I'm looking at an old car or truck and I stick my head in the window and get hit with that old musty smell, there's something about it that takes me back to all the old cars and trucks that have been a part of my growing up. Lonnie said it best, it's just part of the engineering that was available at the time. If you have to explain it to some folks, they'd never understand. It would be like having a war of wits with an unarmerd person. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Tramp's right about the old smell still being in the old vehicles and bringing back memories. I have thought about buying one just to do a daily sniff in it.
~Jim
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 |  Stovebolt scratch 'n sniff? I have a mahogany hutch from my grandmother..probably made in the 20's or 30's..Still smells like her house inside it..nice..I open it up and take a hit once in a while..so yes I can relate.. Keith | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I brought back all the towels and wash rags from the cabin we sold last year to use as rags in the garage and they still smell like tha cabin,and when I get missing the place I do take a wiff to calm me down and when they are all used up I wont know what to do. Jeff | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | That a boy Jeff..
Getting back to an earlier post by 4onthefloor ..that road tube theory makes sense to me..really does..most cars/trucks sinse then reburn those crankcase fumes..
Keith
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I started driving to school in 1958 and I was one of the loudest complainers when engines came out in the early 70's with smog devices because it robbed horse power. But can you if everyones car smelled like the old ones. Like someone said, you are smelling the difference of 50 years of technology. | | |
