5 members (Donf, TUTS 59, Gdads51, massey1951, JW51), 90 guests, and 2 robots.
Topics128,038
Posts1,055,583
#44149 04/11/2004 12:36 PM
With my wife's help yesterday afternoon we bled the brakes on our '51 GMC. I had installed a new dual MC and brake lines. We started by filling up the MC and proceeded with the job. Things seemed to progress OK but we had in my wife's words, a burp, in the MC and fluid would pop out. I guess my question is should the top be on and secured when bleeding the system? It is a bit of a pain to get the bail in place as there is not much room. I was able to to it with a pair of line man's pliers from above though.
Advice more than welcome!!!
thomas,
I just finished installing a whole new brake system with a single MC and had to have the cap secured each time after I filled. I assume doing a dual MC is of no differnce. Did you bench bleed the MC first? I heard it helps so I did mine.
Craig
Every mastercylinder i've ever installed needed to be bench bled.. i usually just put the top back on and a couple rags underneath it... just dont forget to remove them when you are done.. I almost burned my Olds down that way... (always carry a fire extinguisher or two - cheap insurance)
Another quality post.
Real Trucks Rattle
Dual-chamber master cylinders are a pain in the butt to bleed! They trap a lot of air, and must have the bench-bleeding operation done before they're installed. The early method of doing this was a couple of plastic lines installed from the output ports back to the reservoir, and the MC was pumped while mounted in a vise until all the air was purged out. (keep the tubes submerged in the reservoir fluid.) Now, a couple of plastic plugs for the output ports are supplied with the new MC, and the reservoir is filled with fluid, and the cylinder is cycled until all the trapped air escapes through the vent holes above the pistons. Yes, it will bubble and squirt a little fluid in the process, so replace the cover during the first few strokes of the pistons. Once all the air is displaced, install the MC, connect the lines, and bleed the remaining air through the wheel cylinder bleeder ports. It's nearly impossible to get all the air out if you install the MC dry!
Also, to add to the advise of the others, make sure your brakes are adjusted properly. The fluid coming back to the master is coming from the wheel cylinders. When the shoes have to expand a long ways, it takes more fluid going out . Then when you release your pedal, the fluid comes back. It usually comes back fast enough to bubble over the master a makes a heck of a mess. Brake fluid strips paint too.
Just a thought,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Junior Member
Junior Member
I blead the brakes on my 1951 3800 yesterday and used my neighbors compressed air tank. That is the coolest way to bleed brakes -- no pedal pumping -- just move from one wheel to the other and the MC, done in no-time. I don't know if you can buy these tanks or not but they are about half the size of a BBQ propane tank, you add a quart of more of brake fluid, some compressed air and attach the hose via a cap fitting to your MC. Open the valve and presto the whole brake line network is pressurized and it keeps the MC filled to the brim. If anyone would like a picture of this unit I'll post it.
Randy Wilson
Eureka, Montana
1951 Chev 3800
BLUE
1951 CHEVY 1-TON
MODEL 3800
http://geocities.com/gocountry99/
I used a pressure bleeder for many years. The better ones have a rubber diaphragm between the fluid and the air, so they can't mix. One precaution, the fluid can absorb moisture if it's left in the bleeder ball, so don't get in the habit of leaving the ball filled between brake jobs. "Wet" brake fluid has a much lower boiling point than fluid that's been kept away from humidity.
Hello Blue,
please post a pic of the unit you are referring to.
Thank you smile
Junior Member
Junior Member
Mechainiac, I'll try and get the pic up tomorrow night -- Thursday, April 14.
UPDATE: I WAS HAVING TROUBLE POSTING A PICTURE, BUT CAN EMAIL TO ANYONE IF YOU LIKE.
BETTER YET, JUST VISIT THE SITE INFO POSTED BELOW BY JOE WAY ON THIS SUBJECT -- IT TELLS YOU EVERYTHING YOU NEED TO KNOW.
GOOD LUCK,
RANDY
BLUE
1951 CHEVY 1-TON
MODEL 3800
