7 members (gswbbc, Hanks custodian, BC59, 55shaker, dt235sd, wilbur53, Lightholder's Dad),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,048 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44132 12/24/2003 4:53 PM | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | hello all dumb ? maybe get good answer: are all rearends from chevy blazers supposed to be posi traction, I sure hope so cause I have one even if it isn't I;m usin it anyway but just wondering thanks | | |
#44133 12/24/2003 5:03 PM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | nope not very many are, mabe one in ten or one in twenty if it is the GM 12 bolt there all kinds of posi third members for them (not real cheep though) do you know how to tell? | | |
#44134 12/24/2003 6:56 PM | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | oldchevy46 no I dont that was gonna be my next question thanks bud for askin | | |
#44135 12/24/2003 8:54 PM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | once you take the cover off you can see there are 2 difrent kinds, limited slip and full locking, but if you see spider gears than it is not a posin unit there are ways to tell with the cover still on also just buy jacking up the truck or blazer and puting it in gear and trying to turn one wheel | | |
#44136 12/25/2003 10:57 PM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | The way I've tested for a posi rear end is to jack it up til the rear wheels are off the ground (tranny in neutral) and turn one of the rear wheels. If the other one turns in the same direction, it's a posi. If they turn in opposite directions, it's open. I know this works on 63 and later 10 and 12 bolt and GM corporate 7 5/8 inch rear ends. I'm not sure about earlier stuff. Ray Chevy Asylum | | |
