| | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44052 05/05/2003 4:39 AM | Joined: Mar 2002 Posts: 52 Member | | Member Joined: Mar 2002 Posts: 52 | What do ya'll think of this combo, 327 chev 350 hp, 9 inch f-ord rear end w/ discs, turbo 350 tranny- stock replacement?? Is this a bullet proof combo?? Any comments would help me make my final decision worth while. | | |
#44053 05/05/2003 4:52 AM | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | If your swapping in all that why not go with the TH400 or a 700R4. The TH400 is stronger than a TH350. The 350 however has a higher 1st gear ratio. It depends on what your goal is for the vehicle- ie Daily Driver, street rod or a worker. For a daily driver go with a 700R4, street rod or worker go with the TH400. I have run all three and the 400 is best for strength and dependability. | | |
#44054 05/05/2003 4:27 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | sswapp,
The nine inch seems to be plenty tough and there are LOTs of part available for it. The downside is that the wheel bolt pattern won't match the front on a Chevy pickemup. I put a '67 **** rear end under my '49 Chevy pickup for two reasons. 1. The wheel bolt pattern matches the Mopar front suspension and 2.) I already had the **** rear end that was the same width as the Chevy 12-bolt it replaced.
One other reason for the popularity may be because of the abiblity to quickly change gear ratios by just swapping the center section.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#44055 05/05/2003 6:12 PM | Joined: Feb 2003 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2003 Posts: 73 | if you don't already have the 9", let someone else spend the big bucks and find something cheaper like an s-10 rear. s-10 owners routinely upgrade to 8-cyl engines without changing the rear. further, the s-10 rear is the correct width and bolt pattern.
for the tranny, i'd stick with the th350. it's lighter, takes less hp to spin, and it's plenty strong enough for a 350 hp small block.
don't overdesign your drivetrain. think efficiency.
ed | | |
#44056 05/05/2003 8:37 PM | Joined: Mar 2002 Posts: 52 Member | | Member Joined: Mar 2002 Posts: 52 | Sweet, I do already have the **** rear end, kinda dumb luck I ended up with it without forking out anything. My padre is a machinist and can redrill my lug pattern without any problem. Only one question- after I get the correct lug pattern and I get the rotors-calipers to match the front--- is the F-rd 9" going to be to wide?? I guess I can get offset rims, but I'd rather have a little meat to work with. | | |
#44057 05/05/2003 10:09 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | sswapp,
Should be in the vicinity of 62" across the wheel flanges for the AD pickup. I think the '67 LTD rear end I used was 62.5".
#44058 05/05/2003 10:59 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | What parts are you filling the 327 block with?
Rear gear ratio?
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#44059 05/06/2003 1:50 AM | Joined: Mar 2002 Posts: 52 Member | | Member Joined: Mar 2002 Posts: 52 | Probably going to just keep it close to stock and toned down. Haven't gotten the guts for the engine yet. I want to run pump gas so a 9:1 ratio is 'bout it. Bolt on horses like heads, headers, intake, carb, etc. | | |
