0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | I wanted to fill some of the holes in my firewall that won't be needed anymore because I'm planning on installing a v6 with new wiring kit. I'm not sure if I can just weld a plate behind and fill the holes from the front. Or will I need to make plugs to match the holes and butt weld them in? Anyone done this yet? | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | we just cut little square pieces of sheet metal, i was inside the cab pushing against them with a screwdriver my buddy was outside tacking them. welded them up,ground them a little filler and called it good.worked for me...................dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | If you know a electrician ask them to save some knockouts. Throw a magnet on the back and weld from the front. As Dave said grind ,fill, prime and paint. Good luck and have fun Dan | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Call around to sheetmetal shops and see if they have a Rotex punch. If you find one ask them to punch out some slugs to the size you need. If you have a step drill you can bore out the holes to a larger, more common size.
Yes, there are other punches that can punch out slugs but a Rotex is simple and fast with no setup required. Should be able to get all you need for a pittance. You'll just have to hammer them flat, the will come out bent. The punch is used to get a clean hole, not produce a clean slug.
I just don't like the idea of you scabbing a lot of square pieces of metal to the back of your firewall when you can make a nice, clean job out of it. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | What happened to holding a copper spoon behind the hole and just welding it up? I remember reading quite a bit about doing this and for the most part it seems the way to go???? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that'd be the deal for screw size holes Alvin, but for the heater hose/ wire grommet size, some backing helps
Bill | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Thanks Dave,4t6,czechman,Achipmunk,& Red58. I have found that everyones advise is very usable. Smaller holes were welded with a copper backup spoon, had some old electrical boxes some of the knockouts were ok to use,also did find a shop to make some slugs that fit real nice using the Rotex, when I told the guy why I needed them he said it would cost more to do the paperwork so he said don't worry about its on me! 1 hole was sort of long and rounded at the top so a backup plate was used. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Good to hear... I've always felt that no matter how menial or insignificant the job you should always try to do the best you can. It may be something that no one will ever see but you'll know it's there. | | | | | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | I just welded in circles until the hole closed up.... then used the grinder to make it flat.
as above, that's not a very good way to close up the larger holes tho; but it's possible.
another way it to put in a bolt that fits the hole, weld it, then grind off the head.
| | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | i used wahsers i used a step drill to enlarge the holes to fit the washers and when they were welded in i used a coper bar to fill the small hole turned out good
gotta love old trucks
