8 members (cmayna, ShopRag, Cosmo, Eisenholtz, 1955 1 Series, Bill Hanlon, Mike Roache, 1 invisible),
58
Mod | | | Forums66 Topics128,020 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 4 New Guy | | New Guy Joined: Aug 2008 Posts: 4 | I'm not sure this is the correct forum but here goes. I have a 49 half ton and have shaved the handles and put in bear claw latches. My question is do I need to remove the window stop in the door? I tink that the channel if mounted to the side will suffice as it relates to clearance. I hope this makes sense to everyone. I saw an episode of one of the motor head shows with installing a kit and they removed the stop on the car. I wanted someone who has sone this before to see if they have the metal brace between the outside skin and inside door frame. Also, anything to look out for with the window motor and solenoid in the bottom of the door? Thanks
One day I am going to finish this project!
