2 members (mick53, J Lucas),
133
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | The motor in my 58 is a 54 -55 235 from a car with a pg. The port in the head for the temp sending unit (gauge)is 3/8" npt.
The 58 motor was 1/2" npt. I found a ford guage temp sending unit that was 1/4". I bushed it to 3/8" and hooked it up.
Cold the needle starts at half way and as the motor warms up it goes off the the scale.
I am thinking if I get a resistor I can make it read lower. Maybe a light bulg in series would confirm this?
I am wondering if there is an electricial guru that can tell me where to start size wise if I where to buy a resistor?
I could not find a TS unit that was 3/8 npt for a guage
THANKS | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The 3/8 sending unit was mechanical, not electrical at least on my 55 engine. So that is what I have in the 53'. I am pretty certain I didn't use a bushing. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have a new temp gauge in my 54 that reads 20 degrees to high becase it is a shorter probe reading head temp instead of water temp. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | I have an elec gauge in the dash not mech i would like to find an elec 3/8" TS unit for a gauge | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Lindsay; I've been dealing with this same problem on my '49 GMC that has a 261 Chevy engine in it. My gauge is original electric and a range of 100-220 degrees and the sender on the 261 is in the thermostat housing, not on the head. From my experience, you can't add a resistor inline to the gauge to make a difference in offsetting the temp reading (I tried this with all kinds of resistance ranges). This is simply because the sender is a NTC type resistor which stands for negative temperature coefficient. Basically it means that as the temperature rises, the resistance falls and vice versa. The early GMC's used an electric gauge where the Chevy's still had the mechanical one. The problem is matching a sender with the proper NTC resistor to the original gauge range. The old GMC senders are long gone and the newer ones do not match the range. I am going to experiment on a gauge that I just bought where there are two adjusting nuts which are factory sealed on the back of the gauge. I believe that by moving these nuts, it will change the resistance of the gauge and then I can match it to sny sender. The problem will be in getting the sender in water at 100 degrees and keeping it there while adjusting the gauge and then raising the temperature to 220 degrees and keeping it there while I adjust the gauge. Think that it may work but won't know until I try. | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | maybe I'll look at adusting it in the vehicle while it is running. I just need a baseline to be able to jugde when it rises above a normal operating temp. thanks
