| | | Forums66 Topics128,117 Posts1,056,298 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I did a search but couldn't find reference to what I was looking for. My COE has the 2 speed rear axle. I need numbers for gaskets for both the housing and cover. My flaps couldn't help me. Thanks in advance for any help. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I run over the road trucks. We quit using gaskets years ago. So did the manufacturers. Silicon works much better. We used gaskets until probably the 80's and we always had problems with leaks. Instead of removing the third member, we would loosen it enough so that we could wrap a string all the way around 3 or 4 times. That held it longer than gaskets, but silicon is a permanent fix. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I still like to use gaskets for most stuff, usually with Permatex #2 on both sides. However, crenwelge is right, differentials for years now have been assembled at the factory with silicone. I took a Tour of the Dana axle assembly plant near me a few years ago, they used a black silicone on the covers. The new Rockwell/Meritor axle I put in a truck last year said in the service manual to use silicone to seal the third member to the housing. I did and it worked just fine. I Don't care for how silicone looks when it oozes out, so I wipe the extra off with lacquer thinner, or let it set and hit it with the wire brush later. There is still a chance you will find gaskets, and if not you could always cut some out. Have you tried http://www.olsonsgaskets.com/ ?? Grigg | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I don't give much mind to silicon oozing out of my over the road trucks. It is the oil leaks I want to stay away from. However, I have seen guys that are owner operators with "show trucks" take a razor blade to cut the excess silicon away. These are the same guys that polish their wheels with jewelers rouge. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Thanks for the comments. I was aware that silicone alone is a possibility but didn't know that the manufacturers were doing this. I didn't think of Olsen's, even though I have them bookmarked. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Try this gasket, Fel-Pro #RDS 5049
Its for the standard 1 1/2 to 2 ton rear ends. Im not quite sure if the 2 speeds used a larger size or not.
Good luck, Jeff | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I cut out a rear diffy gasket using a pizza box as the gasket material and then sealed it with black RTV.It worked well.Oh Yea, the pizza was good too !!!
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I never used a pizza box because you had to pull the third member out. Using string was the lazy way. You just loosen the bolts, pry the third member away a little and then wrap string all the way round it. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | When I built aircraft engines we would use silk thread on the crankcase halves to seal them. Never used string to seal anything except in old plumbing repairs(lampwick).
