6 members (Guitplayer, Gdads51, Gray_Ghost, sron48, MRMEROTH11, 1 invisible), 89 guests, and 0 robots.
Topics128,068
Posts1,055,882
Members48,428
#439318 08/07/2008 2:46 AM
what do you use to turn that funny cartwheel inside of the brake drums? I prefer use something from the standard toolbox, but I don't want to wreck the teeth
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
seetz: its called a Brake "spoon". One end is sort of straight and the other end is sort of bent. One end makes it easier when tightening the shoes and the other end makes it easy to loosen or back them off. Just depends on which way you want to turn it.
http://www.kd-tools.com/282.htm
http://www.lislecorp.com/tool_detail.cfm?detail=1006
Should be able to get an adjuster spoon from the flaps. The 2 I posted are the most likely brands that you'll find.
Bill Burmeister
thanks! I'm going to try a real spoon. will post tomorrow if it worked or not
I LOVE MY TRUCK
Seetz
pretty much anything reasonably solid & flat will trip the starwheel. I could not find my brake spoon today, so I used a medium flat screwdriver. Right tool-NO, Did it work -YES.
I have brakes now.
Brad
Yup large screwdriver here..but a spoon sure sounds nice
Keith
The spoon is pretty much a screwdriver grind with a bent shank for easier clearance. If you can adjust it with a large screwdriver you don't need the spoon.
Paint & Body Shop moderator
What's a brake spoon cost these days? They used to be about 69 cents. If they were $100 I could see where you guys might be exploring alternatives. As it is, y'all will have outsiders thinking, "Them Stovebolters are tighter than bark on a tree." grin
Bill Burmeister
I USED to use a screwdriver, it worked OK on most jobs. But since I got a spoon, I'll never use a screwdriver again. Never have issues with clearnace or angle, they just work better.
Of course I had a couple adjusters in the back of the dump truck that needed persuasion, but that involved removing the drum and a forcful conversation with a hammer and a punch. grin
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
ok, here's the results: regular spoon DOES NOT work. remember that guy Uri Geller, that bent spoons? well, I can do that too.
brake spoon is 5.49 at Napa. now the star wheel doesn't turn, probably because I turned it all the way back when installing the drum again. so take wheel off etc. again. already ruined a dust cap when the wheel slipped while I was putting it on. (you know what a 19.5" wheel weighs? and that it becomes 10x as heavy when you try to mount it on an 8 lug hub?).
and of course, I take a look to the left under the truck, and somehow nuts on my U-bolts came undone. aahhh. the domino game is in full effect
seems that 2 full years of daily driver duty is taking it's toll on the truck, looks like I'm facing some major servicing.
oh and what started all this? a little rubber boot on the wheel cylinder that came halfway off.
I LOVE MY TRUCK
I have two of them in my tool box. Bought them a way back when at the local Western Auto store.I believe that was in the mid 50s. Cost was less than a dollar a piece.Course with inflation,they are probably a tad bit more now.
Moderated by  MNSmith
