8 members (David Bush, kades51, BC59, MikeE, Bucker, MickeyP, Rexville48, dt235sd),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | what do you use to turn that funny cartwheel inside of the brake drums? I prefer use something from the standard toolbox, but I don't want to wreck the teeth | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | seetz: its called a Brake "spoon". One end is sort of straight and the other end is sort of bent. One end makes it easier when tightening the shoes and the other end makes it easy to loosen or back them off. Just depends on which way you want to turn it. | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | thanks! I'm going to try a real spoon. will post tomorrow if it worked or not | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Seetz
pretty much anything reasonably solid & flat will trip the starwheel. I could not find my brake spoon today, so I used a medium flat screwdriver. Right tool-NO, Did it work -YES.
I have brakes now. Brad
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Yup large screwdriver here..but a spoon sure sounds nice
Keith | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The spoon is pretty much a screwdriver grind with a bent shank for easier clearance. If you can adjust it with a large screwdriver you don't need the spoon.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | What's a brake spoon cost these days? They used to be about 69 cents. If they were $100 I could see where you guys might be exploring alternatives. As it is, y'all will have outsiders thinking, "Them Stovebolters are tighter than bark on a tree."  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I USED to use a screwdriver, it worked OK on most jobs. But since I got a spoon, I'll never use a screwdriver again. Never have issues with clearnace or angle, they just work better. Of course I had a couple adjusters in the back of the dump truck that needed persuasion, but that involved removing the drum and a forcful conversation with a hammer and a punch.  1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | ok, here's the results: regular spoon DOES NOT work. remember that guy Uri Geller, that bent spoons? well, I can do that too. brake spoon is 5.49 at Napa. now the star wheel doesn't turn, probably because I turned it all the way back when installing the drum again. so take wheel off etc. again. already ruined a dust cap when the wheel slipped while I was putting it on. (you know what a 19.5" wheel weighs? and that it becomes 10x as heavy when you try to mount it on an 8 lug hub?). and of course, I take a look to the left under the truck, and somehow nuts on my U-bolts came undone. aahhh. the domino game is in full effect seems that 2 full years of daily driver duty is taking it's toll on the truck, looks like I'm facing some major servicing. oh and what started all this? a little rubber boot on the wheel cylinder that came halfway off. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have two of them in my tool box. Bought them a way back when at the local Western Auto store.I believe that was in the mid 50s. Cost was less than a dollar a piece.Course with inflation,they are probably a tad bit more now. | | |
