3 members (Rich'sToys, 54farmtruck, 1 invisible), 96 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
The motor in my 58 is a 54 -55 235 from a car with a pg.
The port in the head for the temp sending unit (gauge)is 3/8" npt.
The 58 motor was 1/2" npt. I found a ford guage temp sending unit that was 1/4". I bushed it to 3/8" and hooked it up.
Cold the needle starts at half way and as the motor warms up it goes off the the scale.
I am thinking if I get a resistor I can make it read lower. Maybe a light bulg in series would confirm this?
I am wondering if there is an electricial guru that can tell me where to start size wise if I where to buy a resistor?
I could not find a TS unit that was 3/8 npt for a guage
THANKS
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
The 3/8 sending unit was mechanical, not electrical at least on my 55 engine. So that is what I have in the 53'. I am pretty certain I didn't use a bushing.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
i have a new temp gauge in my 54 that reads 20 degrees to high becase it is a shorter probe reading head temp instead of water temp. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I have an elec gauge in the dash not mech
i would like to find an elec 3/8" TS unit for a gauge
Regards,
Lindsay
Lindsay;
I've been dealing with this same problem on my '49 GMC that has a 261 Chevy engine in it. My gauge is original electric and a range of 100-220 degrees and the sender on the 261 is in the thermostat housing, not on the head. From my experience, you can't add a resistor inline to the gauge to make a difference in offsetting the temp reading (I tried this with all kinds of resistance ranges). This is simply because the sender is a NTC type resistor which stands for negative temperature coefficient. Basically it means that as the temperature rises, the resistance falls and vice versa. The early GMC's used an electric gauge where the Chevy's still had the mechanical one. The problem is matching a sender with the proper NTC resistor to the original gauge range. The old GMC senders are long gone and the newer ones do not match the range. I am going to experiment on a gauge that I just bought where there are two adjusting nuts which are factory sealed on the back of the gauge. I believe that by moving these nuts, it will change the resistance of the gauge and then I can match it to sny sender. The problem will be in getting the sender in water at 100 degrees and keeping it there while adjusting the gauge and then raising the temperature to 220 degrees and keeping it there while I adjust the gauge. Think that it may work but won't know until I try.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
maybe I'll look at adusting it in the vehicle while it is running. I just need a baseline to be able to jugde when it rises above a normal operating temp.
thanks
Regards,
Lindsay
