0 members (), 45 guests, and 3 robots.
Topics128,049
Posts1,055,637
#43869 01/21/2003 5:58 AM
All right i have a 1950 1 ton chevy truck with a 235, i also have a 5:11 rear end. What would i gain by going to better ratio for highway driving? Would it help that much? And if it would be a good idea to do this? What will fit under it? with a minimal amount of work. I want to keep the dual tires on the back. Well thanks in advance.
Hudson,
1 1950 chevy 1 ton
1 1954 Hudson hornet four door (real hot rods do not have valve covers wink
1 Chevy corvette (HA HA HA HA HA HA HA HA HA IN MY DREAMS)
#43870 01/21/2003 6:06 AM
Hey Hudson, I am in the same boat with my 59.
Check this out - its what I am angling for right now for mine.
Kook\'s swap
#43871 01/21/2003 6:14 AM
thanks that is a good idea.
Hudson,
1 1950 chevy 1 ton
#43872 01/21/2003 8:35 AM
I had Randy's do the work, just to be sure I didn't make any expensive errors. I would have gone with 3.90:1, except the used 4.11's were cheaper and I still haul stuff. Wound out in 4th used to get me close to 40 mph, now it hums along at 50+ and I still have the granny low. smile
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
