1 members (FishinToms53),
74
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 2,400 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,400 | My old '59 Viking 40 just amazes me. I have hauled many loads of road rock, lumber, retaining wall block, mulch etc and she just keeps on purring like a kitten. Earlier today, I hauled a couple tons of 3/4" limestone crush and run to be used for a retaining wall base and once again she didn't let me down.
The only thing my truck really needs (besides electric wipers) is a cup holder. How about some creative ideas on how some of you may have solved this issue.
I already have a few ideas myself, but will welcome any and all suggestions, as I like to do things right the first time.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | When all this cup holder craze started the quick fix for those suffering cup-holder-envy was one of THESE. or something like THIS. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the original cup holder ain't handsome, but should always be handy  Bill | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I purchased one of those 44 cent holders. It didn't fit my cup and bounced around spilling coffee everytime I hit a bump. So what I did was got a piece of heavy wall PVC pipe, cut a line down one side then using a heat gun I flattened it out. Once it cooled I marked a 3/4 inch wide cross. I cut that out and using the heat gun heated one section at a time forming it to fit my cup exactly. After some sanding I painted it to match the interior. I used a bolt and a wing nut to attach it to the bottom of the dash. It works great, and looks pretty darn good as well. | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | When I was in the irrigation business full time, I carried one of those big 44 oz cups. I found a 4" pvc pipe cap would fit the cup nicely after I cut a small section out of the side of the cap to allow room for the handle. I then screwed it to the floorboard of the superduty F-250 I was driving.
I was considering doing the same thing in the semi until I priced the cap--they have quadrupled in price!!! I ended up using a smaller cup with the style of cupholder in Czeckman's second picture. I broke off the tab that goes down into the wndow channel and used one of the screws for the ashtray to secure the cupholder to the lower dash of the KW T-800. There might be someplace that you could do the same thing with. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I always thought it was snugging your can of Bud between your legs. Always worked for me.  | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Yea, when I wanted mine extra cold I used to put it between my ex-wife's legs :mad: | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Once again red58 beat me to it. I have a roll of duck tape sitting on a piece of 1/4 inch plywood, sitting on my seat. It will hold a Starbucks type paper cup (grande) without any spills.
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Aug 2008 Posts: 19 Apprentice | | Apprentice Joined: Aug 2008 Posts: 19 | I put mine on the inside of the glovebox door. Works well, and they're not visible when you're not using them. | | | | | Joined: Nov 2007 Posts: 131 Certified Bolt Nut | | Certified Bolt Nut Joined: Nov 2007 Posts: 131 | I like the inside of the glove box...do you have pictures? | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I am working on making the speaker grill hinge down to give me another glove box like area in my 53. I hope to put a new radio in there and still have some cd storage. Back to the cup holder. I think I can adapt the ashtray to a cup holder. Maybe use a hole saw to cut out hardwood for the holder. Anyway if it works out I will post the results. I have an extra to play with. | | |
