| | | Forums66 Topics128,049 Posts1,055,652 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | Hey guys, is it tough to rebuild rochester b or should I send it out to be done.
1957 3805 Panel It's not how you fall down, but how you get back up.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is the simplest to do as carbs. go. If you have any mech. expertise it should be no problem. Do not try to take the throttle or choke plates or shafts out. Make shure the power valve moves up & down & kicks the ball off the seat. Make shure there is a passagway in the base gasket for thr vacuum hole in the bottom of the carb to get vacuum from the manifold. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I have had very good results with Daytona Parts Co. rebuilding carbs in the past. Google Daytona Carburetors. You might get lucky and put a kit in it and be OK. Usually these old carbs are worn to the point that the throttle shafts have to be bushed along with other machine work for a first class job. Cleon | | |
