3 members (1955 1 Series, Otto Skorzeny, Gdads51), 51 guests, and 1 robot.
Topics128,037
Posts1,055,580
#438588 08/04/2008 8:04 PM
Hey guys, is it tough to rebuild rochester b or should I send it out to be done.
1957 3805 Panel
It's not how you fall down, but how you get back up.
Riding in the Passing Lane
It is the simplest to do as carbs. go. If you have any mech. expertise it should be no problem. Do not try to take the throttle or choke plates or shafts out. Make shure the power valve moves up & down & kicks the ball off the seat. Make shure there is a passagway in the base gasket for thr vacuum hole in the bottom of the carb to get vacuum from the manifold.
1972 Chevy c10 Cheyenne Super
I have had very good results with Daytona Parts Co. rebuilding carbs in the past. Google Daytona Carburetors. You might get lucky and put a kit in it and be OK. Usually these old carbs are worn to the point that the throttle shafts have to be bushed along with other machine work for a first class job.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
31,32,33 #439483 08/07/2008 4:13 PM
I just got done rebuilding mine and it was SUPER easy! This website helped a lot too (considering I lost my instructions. DOH!)
http://www.classictrucks.com/tech/0802ct_rochester_carburetor_rebuild/index.html
It has a lot of pictures as reference.
Good luck!
Us girls like them ol trucks too!
New Pics of my 53 Chevy:
Side: http://tinyurl.com/3xtgfa
Dash: http://tinyurl.com/2npafu
Front: http://tinyurl.com/3dhlkv
Savage
