2 members (baldeagle, dunfire), 86 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#438056 08/02/2008 6:25 AM
I am concidering retro fitting a power front disc set-up on my 56 3100 with a 235 6cyl. Will this motor create enough vacume to operate the wipers and brakes at the same time?
Brad
brsdb3381 #438102 08/02/2008 3:31 PM
Brake boosters don't require that much vacuum once they are intitially evacuated like right after start up. If the booster leaks, then it would affect the wipers, and the engine idle. There should be enough vacuum to go around if the wiper motor and booster are in good shape,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #438155 08/02/2008 8:03 PM
Thanks Scott, I was reading another thread and thought of this, they were having trouble with the wipers alone.
Brad
