10 members (Johnny Rib, 68ironhead, 2-Ton, 1955 1 Series, JW51, baldeagle, Guitplayer, walter74, Eisenholtz, Peggy M),
104
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | I am concidering retro fitting a power front disc set-up on my 56 3100 with a 235 6cyl. Will this motor create enough vacume to operate the wipers and brakes at the same time? Thanks Brad | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Brake boosters don't require that much vacuum once they are intitially evacuated like right after start up. If the booster leaks, then it would affect the wipers, and the engine idle. There should be enough vacuum to go around if the wiper motor and booster are in good shape, Scott | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Thanks Scott, I was reading another thread and thought of this, they were having trouble with the wipers alone. Brad
