| | | Forums66 Topics128,081 Posts1,056,069 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 18 Apprentice | | Apprentice Joined: Jul 2008 Posts: 18 | I have a 1954 chevy 235 I just bought. I haven't driven it on the road yet.It hasn't been driven much for several years. It idles rough and lunges some while idleing. The spark plugs are not oiled but have heavy carbon deposit. As soon as I cleaned them they have a deposit. After the engine warms up I start getting smokey exhaust and it smells as thought it is burning to rich. Compression check shows 135 to 145 per cylinder. Is this a carburetor problem? Someone installed an electronic ignition on it. Scott Brown [email protected]
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Sure sounds like too much fuel to me. A good cleaning of the carb seems to be in order. You could have a float sticking or other issue that a simple tear down & cleaning could fix.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Well another Kansan might as well join in. I would agree it is a carb problem. If it is a Roch. model B they are pretty simple. Check the float for haveing gas in the pontoons. Check the power piston makeing shure it's not stuck. Make shure there is a passigway in the base gasket so vacuum can get to the hole in the bottom of the carb. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Yup sounds like ya got a carb in need of a trip to the E.R. ...for some TLC | | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | BROWNIE1
Fuel, Fuel, and more Fuel!
Do the standard float, Pump, Jet check.
Make sure to replace the plugs when you find the problem.
Carbon tracking is not repairable!
Good Luck. | | |
