1 members (RLB), 145 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#437397 07/31/2008 12:10 AM
Apprentice
Apprentice
I have a 1954 chevy 235 I just bought. I haven't driven it on the road yet.It hasn't been driven much for several years. It idles rough and lunges some while idleing. The spark plugs are not oiled but have heavy carbon deposit. As soon as I cleaned them they have a deposit. After the engine warms up I start getting smokey exhaust and it smells as thought it is burning to rich. Compression check shows 135 to 145 per cylinder.
Is this a carburetor problem? Someone installed an electronic ignition on it.
Scott Brown
[email protected]
Ex Hall Monitor
Ex Hall Monitor
Sure sounds like too much fuel to me. A good cleaning of the carb seems to be in order. You could have a float sticking or other issue that a simple tear down & cleaning could fix.
Riding in the Passing Lane
Well another Kansan might as well join in. I would agree it is a carb problem. If it is a Roch. model B they are pretty simple. Check the float for haveing gas in the pontoons. Check the power piston makeing shure it's not stuck. Make shure there is a passigway in the base gasket so vacuum can get to the hole in the bottom of the carb.
1972 Chevy c10 Cheyenne Super
Yup sounds like ya got a carb in need of a trip to the E.R. ...for some TLC
1952 Chevy Shortbed
Photos in Photobucket
BROWNIE1
Fuel, Fuel, and more Fuel!
Do the standard float, Pump, Jet check.
Make sure to replace the plugs when you find the problem.
Carbon tracking is not repairable!
Good Luck.
"It's not a wreck......It's a natural resource!"
Quote-Doc Bob circa 2006
DOCS CLASSIC GARAGE
Specializing in Hot Rods,
Customs & Street Machines.
My pictures at..........
1936 Chev 1/2-Ton Holden Body
confused? http://www.koalanet.com.au/australian-slang.html
