| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | just thinking, as anyone seen a late model bed put on a 3/4 ton truck.I really want a truck bed, but didnt want to cut the frame to do it. the 3/4 ton is 10inches longer than a 1/2 ton. any if you have seen one what would did it come off of. | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | i saw one at a show and i think the bed was off of a '88-'95 chevy/GMC pick-up | | | | | Joined: Jun 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 71 | well is that a shortbed your comparing to your truck? what about a longbed? would a newer longbed fit? | | | | | Joined: Dec 2007 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 96 | It is not too hard to cut the frame. There is a straight section of rail behind the cab that you can take the excess out of. I ended up whacking 7" out of mine before welding it back together. Lots of measuring to keep it square, weld slow, and reinforce the weld. This centered the wheels in the fenders pretty good.
I have seen a couple of trucks with late model 1/2 ton step side beds. They just do not seem right to me. I am going to rework an original 1/2 ton short bed that I picked up for $100. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've never seen a modern bed on an old truck that I really liked. Look for an original long box, they aren't too hard to find.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I've seen a mid '60's step side bed mounted on a '53 Chevy pick up. The '53 running boards were cut to match the curves of the new bed steps. Overall the look of the truck changed because of the '60's style bed fenders. They look too big for the truck. Work with what you got - this particular guy did a nice job. He used what was available to him. If money isn't a factor in your decision- get the correct bed for your truck. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I've never seen a modern bed on an old truck that I really liked. I agree...but in the end, it's your truck so do what seems right to you.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Feb 2009 Posts: 4 Apprentice | | Apprentice Joined: Feb 2009 Posts: 4 | Hey guys, I have a 48 and installed an 88 stepside/shortbed on it and I didn't cut the frame. I did cut the 88 febders off and glassed on a pair of 48 glass fenders that are 2 1/2" wider to accomodate the 10" wide rimes. I then added some glass "filler" pieces on the front of the bed to follow the contour of the back of the cab. Send me you email address and I'll send pictures. [email protected] | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I just saw a couple of these trucks with modern pickup boxes, painted to match and they looked super. One was fitted very nicely to the contour of the old cab, fine fab job. Also I've seen a modern bed on the big Nissan or Toyota trucks that has a nice curve where it meets the cab????
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You won't find a late model bed this will fit without cutting the frame, no one has made a long stepside bed since '91.
Bill Burmeister | | | | | Joined: Sep 2009 Posts: 69 New Guy | | New Guy Joined: Sep 2009 Posts: 69 | i think they look gross. but its not my truck its yours. i would hit up craigslist, or your local pick-a-part. a guy down the stree from me did this (not a long bed, and on a 1/2) but just get the measurments correct, and be patient
2000 Nissan Frontier, 3.3L (sold) 2006 Chevy Cobalt SS, 2.4L 1952 Chevy 1/2 pickup, 235 c.i. I6 when life speeds up, downshift
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have also seen late model beds on AD trucks and it really looks weird. I think the problem is the back half of the truck is one era while the front is another. The only way it would look right, it seems, is if the front is jazzed up in some custom effect. That's my opinion but it's your project; make it the way you like it.
~Jim
