9 members (panel fan, GMCJammer51, Hush, wilbur53, Peggy M, Tinker5, TUTS 59, Wickedbass, 1955 1 Series),
90
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Guy told me yesterday that front end stuff (brakes and stuff) from 73-77 would bolt right on. Is this correct? Virg | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Tons of stuff on this swap in the search forums. Your best bet would be the stuff from a 71-72 model. Nearly a drop in deal(a few bolt holes need enlarged)and parts are very easy to come by without buying the more expensive kits from the aftermarket vendors. You might even get lucky and find everything you need in one fell swoop at the local salvage yard, from one donor truck. Good luck and enjoy the better brakes, steering, and all. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Actually, you can use up to an '87 model. I used a '79 model on mine. Here are a links that I posted but there's alot of info on this site on the subject. Also check out these two links: Link 1Link 2Good luck.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Bolt right on to what?
"front end stuff (brakes and stuff)" won't bolt up to a straight axle. What Tramp and Mobileortho are referring to is the entire suspension swap.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I wonder what year he is working with. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Thanks....I have a 48 I just bought and a 50 that I put a 283/PG in.
