2 members (klhansen, Peggy M),
167
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | I just dismantled my parking brake on my 3805 and was extra careful not to harm any springs that I removed. Also when I did the same to my brake pedal arm there were springs there too. Other than cleaning them up and re-using them in their worn state, does anyone have a source for such items? Any info would be greatly appreciated. Slim.
1957 3805 Panel It's not how you fall down, but how you get back up.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | 3805 sounds like a COE. IF so you might get better answers over on "Big Bolts".
~Jim
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | CS,
Many hardware stores and industrial supply stores have coil springs in assorted sizes. You should be able to match up a new one to replace the old ones. Also try the internet. Look for something that matches your spring. Wire diameter, spring height, diameter and coil count.
If the spring is in good shape, just clean it and reuse.
Lonnie | | | | | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | So far I've done a little searching and found www.leespring.com and I'll keep looking. The wire diameter I guess would have to measured with a sliding or dial caliper?
