2 members (klhansen, TUTS 59), 64 guests, and 2 robots.
Topics128,066
Posts1,055,873
Members48,428
#436925 07/29/2008 2:48 PM
I just dismantled my parking brake on my 3805 and was extra careful not to harm any springs that I removed. Also when I did the same to my brake pedal arm there were springs there too. Other than cleaning them up and re-using them in their worn state, does anyone have a source for such items? Any info would be greatly appreciated. Slim.
1957 3805 Panel
It's not how you fall down, but how you get back up.
3805 sounds like a COE. IF so you might get better answers over on "Big Bolts".
~Jim
CS,
Many hardware stores and industrial supply stores have coil springs in assorted sizes. You should be able to match up a new one to replace the old ones. Also try the internet. Look for something that matches your spring. Wire diameter, spring height, diameter and coil count.
If the spring is in good shape, just clean it and reuse.
Lonnie
So far I've done a little searching and found www.leespring.com and I'll keep looking. The wire diameter I guess would have to measured with a sliding or dial caliper?
1957 3805 Panel
