| | | Forums66 Topics128,053 Posts1,055,777 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I have to work on the brake system on the my 1948 2ton. I pulled the second rear wheel today. The wheel cylinder is frozen, in that the adjusters won't turn. The entire linkage is pretty stiff and rusty. I thought the rears on the 2tons had two cylinders per wheel? The shoes look okay, and I may take in the drums and see if they can be turned. When I pulled the axle out of the rear end it looks as though there may be some water in the differential, the splines looked a little rusty. Is that gasket going to be available if I remove the cover on the differential? After dinner I will start on the front wheels. Dang those wheels are heavy. I will most likely have to do the king pins too the upgrade the safety factor. Steers like a boat going down stream. http://community.webshots.com/user/Super55Canada?vhost=community&action=favoritePhotos A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jan 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 66 | You can get brake cylinder rebuild kits for those from Jim Carters Classic Truck Parts. Take your cylinder apart and as long as it isn't pitted up much, you can probably hone them and they will be fine. You may get differing opinions on the pumpkin gasket, but lots of people just say to clean both the cover and the differential very well and use rtv gasket sealer.
As far as steering, you can check the kingpins by jacking the wheel up just high enough to get a bar underneath the wheel and then lift it up and see if it moves much. If it's pretty tight your problem may not be the kingpins. The sloppy steering could also be the tie rod ends or the pitman arm adjustment, or the steering box.
Jon
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Thanks for all the pointers. This is my first truck restoration and I only have one tractor restoration that is not quite finished. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | The 2 ton brakes with dual cylinders on the rear were introduced in 1951. Our trucks use the Huck brake system. I went thru the brakes on my '49 2 months ago. Between my Flaps and Jim Carter I was able to find everthing I needed. I had the shoes relined by Dallas brake and clutch. You are right those wheels are heavy. Brake work is not my favorite thing. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Raybestos Wheel Cylinder Kit # WK104 has the 1 1/2" cups and spring if you can rebuild your old wheel cylinders. It also comes with the dust caps for the later 51 and newer wheel cylinders.
Your gasket for the differential is gonna be Fel-Pro #RDS 5049, at least that should be for the front of it, which I also used for the rear.
If you need to replace the pinion seal its, National 41130N (2.598" x 3.481" x 0.50")
Good luck, Jeff | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | DV ALDIS on fraser street can supply w/cylinders and can reline and machine the rear brakes.... | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Dave, I may take the drums to DV Aldis. The shoes are in really good condition. The odometer is low, so I think this truck sat around too much. That's why the wheel cylinders are so rusted up. Looks like I will put in new cylinders, new flexible lines, and maybe a new master cylinder. Jim Carter has a new master cylinder for $95, the front wheel cylinder for $32, rear for $75. The 3 brake line hoses for $12.30 each, the block attaching bolt for the rear for $2.61 each, the plugs for the front adjusting holes (which were missing) for 38¢, parking brake boot for $3.56 for a total of $359.05. I don't think I can be anywhere close to that on my new cars. However the HydroVac is a whopping $527.
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You may be able to have some of those cylinders relined with stainless steel sleeves for less than a new one. Then you have a better quality cylinder than new.
The stainless steel sleeve last a very long time and give no trouble, when I do any brake work I have them all sleeved.
I have posted the info before, search for "Mark The Machinist" as he is the best I know of for stainless steel sleeves.
Grigg | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Found the info:
The guy to have stainless sleeve your cylinders is: Mark "the machinist" Frappier 82 Mountianview St. Agawam, MA 01001 413-789-8665, or 800-528-5235 A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Seems you oughta be able to get the Hydrovac rebuilt for a lot less than $500. I'd check out www.precisionrebuilders.com Our local truck shops send stuff to them. Or check with the local brake house you're talking about. We're just finishing brakes & wheels on a '44. We sepaerated the lines and blew out the old brake fluid. Little less contamination that way, I hope. -Michael | | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | For rebuilt hydrovacs I would look at: http://www.bscparts.com/index.phpThey show 1 ton units for $194. Maybe they will do yours for about the same money? Paul | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Do the Hydrovac yourself! So long as you take some pictures of the tear down, they arent hard to rebuild.
ABS Power Brake has NOS units for about $150. You can get basic kits (all internal seals needed) WITHOUT the control body diaphragm, lead faced valve and the power cylinder seal for about $50. You may not need those three components.
BSC is a pain in the butt to get kits from as they would rather you send in yours for a rebuild or replacement, but if you argue you can get kits. They DO NOT like responding via email so your better off calling.
Jeff | | |
