| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | Does anyone know the correct size of the hand crank for a 41 - 46 pickup. I see them on EBAY in all shapes and sizes. I have seen on that appears to have a lug wench on one end and the other end has a straight shaft with a pin thru it, approx. 18 inches long with a double bend, if that makes any sense.
Thanks in advance. | | | | | Joined: Mar 2005 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 76 | about 28-29 inches.thanks | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | Does it have a pin thru one end and a socket on the other?
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | The right crank handle has the pin through the end. it fits into the crankshaft. The F#@D crank has a socket end to fit the bolt that holds the pulley on the crankshaft.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
