5 members (Hanks custodian, Phak1, Lostbuthaulinass, homer52, Wheelie), 138 guests, and 3 robots.
Topics128,042
Posts1,055,519
Members48,424
#432765 07/15/2008 2:16 AM
Does anyone know the correct size of the hand crank for a 41 - 46 pickup. I see them on EBAY in all shapes and sizes. I have seen on that appears to have a lug wench on one end and the other end has a straight shaft with a pin thru it, approx. 18 inches long with a double bend, if that makes any sense.
Thanks in advance.
1 Offline
about 28-29 inches.thanks
Does it have a pin thru one end and a socket on the other?
The right crank handle has the pin through the end. it fits into the crankshaft. The F#@D crank has a socket end to fit the bolt that holds the pulley on the crankshaft.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
