1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Is it normally avalable locally or do I have to order it from the web? Where do you guys suggest getting it?
Thanks Brad | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check your FLAPS, some of them carry it, especially if they have a good range of body work supplies
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Its also available from JimCarter. If you are a stovebolt contributor you can get 10% off and only charged actual shipping. That made it the best deal going when I bought mine. You will also see it at some of the swap meets but it will be a little higher. Its dang good stuff! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Check in the links section of the 'bolt. There is a specific section in Parts. Click on corrosion fighting and you'll see an index of POR dealers. Hope this helps! Jock. P.S I've just received £65($120 approx) worth of their products  , and as Alvin says "it's dang good stuff!" It is quite expensive but you get what you pay for!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Rust convertoe or por 15? Found this on the Eastwood site also, any comments or users?
http://www.eastwoodco.com/jump.jsp?itemID=852&itemType=CATEGORY&path=1%2C3%2C688%2C821&KickerID=412&KICKER
Brad | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I use the Rust Encapsulator and their Rust Converter and like both products, especially the Converter... it's water based and very user friendly.
I can't vouch for the long term effectiveness of either product. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I just used Zero Rust on some parts. It is easy to use and goes on great, but I don't know the long lasting effects. There is an article in Tech Tips here on the Bolt, look under Rust Removal. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
